The Harbor Freight PASS/FAIL Thread...
winlinmac
USA
The contractor I hired to do the plumbing uses the following tools from HF. Never let him down, gets the job done; he owns professional tools as well such as Dewalt & Ridgid,
HF Electric Cut Off Tool (Drill Master)--PASS
HF Angle Grinder (Chicago Electric)--PASS
HF Multi-Tool Oscillating Tool (Chicago Electric Pro)-PASS
wildbill23c
Idaho
Which angle grinder are you using? 4-1/2"? I have an old 4" from HF that I've used a lot over the years, it still works great.
winlinmac
USA
I used to have the Chicago Electric Angle Grinder but had to return it due switch malfunction. The plumber seems to never had a problem with the Drill Master though.
Clik
Highest Mountain in Western, MD
I don't get but a couple hours of total run time out of a drillmaster angle grinder. If you are just grinding sheet metal you might get by but grinding welded joints, etc they don't have any power and don't last. Their drills smoke easily too. I do rob the bearings out of them to use on my Jet bandsaw guides. I can buy the whole angle grinder cheaper than just the bearings from Jet.
wildbill23c
Idaho
That's weird. I've beat the **** out of mine over the years. I think mine is about 6 years old, and I've used it for cutting, grinding, etc. It works great, and if it died the next time I used it, I wouldn't be upset. It has served its purpose for many projects, and it paid for itself the first use. I think I got it for $10...they never have them that cheap anymore LOL.
Sambar Stag
Hamburger Press-#44934 PASS
Yeah, I know most folks here don't think of Culinary tools when you shop at HF. But this press allows you to get a consistently sized, juicy burger off the grill. You can mix things into your patties (seasonings, bacon, cheese in the center, etc.). Makes up 1/4, 1/3 or 1/2 pound burgers one at a time. Easy to use and clean, unlike the Williams of Sonoma one that I also have but don't use any more.
Watch case opener #91550-pass
Watch link remover #66267 - pass, but barely. Takes a lot of care to position the pins properly and keep from bending the pin pushers.
SteevoLS
I use the AAAs all the time in small flashlights and they work fine.
Sent from my SPH-L720T using Tapatalk
PassnThru
Bowling Green KY
4 inch diamond cup turbo wheel. Just did some grinding on 12 year old concrete and this delivered. In fact, this was my first try at grinding concrete and I was surprised at how quickly you could get in trouble with this wheel. Long term - I don't know but for a quick job it will do it.
esacfrank
Hartford, CT
3/4" breaker bar snapped - fail they replaced it for free - pass
3/4" torque wrench no torque break away - fail they replaced - pass
3/4" ratchet broke - fail they replaced it free - pass
The Pittsburgh tool line has lifetime guarantee, they replaced the above with NO RECEIPT. no hassle. I like it
SteevoLS
Apparently the moral of the story is don't buy any of the 3/4 tools!
kn51
Sweet Old Bill
N. California
Used the 18 piece Brake Pad Caliper tool set, Item # 69053 ; a definite pass. It was on sale for $44.99. I found a returned set for roughly $25. It worked quite well and made replacing the rear disc brake pads an easy job.
lightning02
Which 3/4 breaker bar? Do you have a link?
babewatcher
East
What the heck are you working on? I work on School Buses and very rarely have to break out the 3/4 stuff.
Scimmia
There's a whole lot out there bigger than school buses. I use 3/4" stuff all of the time on farm and construction equipment.
dodge610
North Canton Ohio
Definate pass and most bang for the buck is the HF 26 in. combo stack. plenty of room for some of my tools keeps everything organized. Drawers operate smoothly.
fourtythree
WV
jerseykat1
Central New Jersey
I'll second that. I have the set and is built very well, the adapters are magnetic as well.
Sent from my Nexus 6P using Tapatalk
jerseykat1
Central New Jersey
Fail! This clamp bent on me after doing just 1 side it will then try to drive the ball joints in crocked. Don't bother.
FigureItOut
Bentonville AR
Massive fail, exchanged it and gave it another chance, same garbage, but it sure does have a nice feel.36ee615585af134f62b18a7d15195c2a.jpg
Definite pass, has no problem popping 1/8" steel/steel rivets dependable, feels like it would go bigger easily.f10759b6227702fa7bdac3981637433d.jpg
Also a pass, but gives much better results with higher quality rivets sourced elsewhere.b137392ad83e355a41d09eaf640ea71c.jpg
Tentative pass, just got it and have installed several 1/4" 20's with good results. Curious to try it with smaller steel rivet nuts.69273a65d5378df9f601da351ea7da16.jpg
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
vetron
Idaho
fail-garden hose: didn't last the first 30 seconds before it exploded!
fail-snap ring plyers: broken ends grrrr
fail-camo tarp: in the sun it drys out fast and shreds in less than a few months outside
dledmo
And it's weird that 1/4" drive is used so often on commercial aircraft. Lots of little fasteners
619DioFan
San Diego , Ca.
EPDM tarp straps ( haul master ) complete garbage. rainy day and needed to tarp a load on a flat bed at work and the truck tarp straps had " walked away ". stopped at HF and bought a twenty piece set ( 13.00 ) they started to break as soon as I got up to freeway speed with the wind hitting the tarp. probably would have had better results with shoe laces. on a side note the EPDM tarp straps I keep at home are REESE brand from walmart. they have held up great.
skulldrinker
Bolingbrook, IL
Were you using an impact or by hand when it bent? I have the same one but haven't used it yet. I hear people buy the OTC clamp to replace it.
Sent from my LG-H811 using Tapatalk
redsand187
Washington
are the Harbor Freight "Jumpstart Battery packs" any good?
Ones like this. You routinely see them in the coupon ad's for $39
$10 gets you 2 additional years of replacement coverage. Take it back in 2 years, because the battery is probably junk, or is weak, and get a replacement, purchase another 2 years of coverage on the replacement, rinse repeat :evil:
