What Material?
WoodyZiegler
We bought a small bungalow home near the sea just to get close to my work. The problem is we kinda want to change the garage gate. What is the best material to use? I heard metal easily rusts when near the sea. So is wood the better choice?
kwoswalt99
Detroit
I would say wood would be the best choice, but may cost too much. I like wood so that's my default answer. Are you gonna build it yourself?
pjboy
virginia
do the wood you can make any design you want,to match your setting ,use pt,redwood,cedar, and paint or treat the wood your preference.How big is gate?
Cyberbear
California
Depends on the look you want. Wood will always be old looking near the ocean because of the salt water. Drive around your area and see what is being used.
The nice thing about wrought iron is that it can be galvanized or powder coated to resist the ocean water and salt. Wood requires constant maintenance, but steel can be redone w/o needing to make a new gate each time. It all comes down to time and money.
maxpower_hd
Massachusetts
It also depends on the intended use of the gate. Is it for security, privacy, keep a dog in, etc. Vinyl may be an option as well.
Kensgarage
The initial cost will somewhat be a slam but frame it out in stainless rect box tubing and hinges-hardware and board it with 3/4 x 5 or 6" teak.You'll have a 50 year gate if oiled once in a while.
Call around. Don't let the stainless scare you.A simple rectangular frame of 1x3 rect box with cross bracing won't be that bad.
simple design=simple maintainence
theoldwizard1
SE MI
PVC is great for durability, but you have a limited choice on style. Also rails (horizontals) and gate post must be reinforced with aluminum box/channel sections.
W
WoodyZiegler
We decided on wood. What kind of wood though? It's not that big of a gate. Maybe around 6-7 ft tall, 13-15 ft wide.
matt_i
SE Michigan
The classic outdoor wood would be redwood. Or cedar. Could be teak or ipe. All depends on your budget. They will all fade to grey in the sun unless a UV protectant is applied and reapplied.
chruler
Vermont
Yup. Cedar or redwood. Lightweight and lasts way longer than most other soft woods. Got to apply a UV coating if you want the color to last.
kbs2244
Which "sea?"
The east coast and the left coast are very different places.
nadogail
Coronado, CA
Mild steel with a good coat of well primed paint, Frequently maintained.
Here on the island my gate has been in place since 1988, 27 years, in a Southern CA beach city.
