CM Block Grinder power switch - replacements
torqueman2002
SE Michigan
Jan. 21 2018 - Because of PhotoBucket'c change in 3-rd party hosting, this thread has been edited to post pictures directly. Therefore, the first post has been split and continued begning in post #22 , below.
The Craftsman vintage grinders with Block-style-motors have a number of different switch styles, depending upon HP and year of manufacture.
For broken switches with plastic bodies and toggles like the one below, I have adapted a switch with a metal toggle.
Link to restore --> http://tinyurl.com/CM-0-75HP-397-19350-Berry
While the above fix works very well, it does take some time, material, and effort.
I want something that is a 'snap-in' solution.
I found that 3 power switches to some Bunn coffee makers will work.
The test dummies:
Left - flat-top 1/2-HP m-397.19441 with a red/black power switch,
Right - round-top 1/3-HP m-397-19581 with a black/*********** switch.
The power switch (PSW) cut-out details.
Slight narrowing in the center.
Continued on post #22, below.
T
torqueman2002
SE Michigan
T
torqueman2002
SE Michigan
McBrownie
Cleveland, OH
McB - I'll check. The OWWM poster said his search found they were not available, but maybe he just checked searsParts and eReplacemetparts.
Here's my thought. I worked for a power tool switch company years ago. We didn't make that style, but had boxes of old stock stored away "just in case". It's a long shot, but contacting the company directly (if they still exist) might land some NOS. You never know.
StillTooManyHobbies
Port Tobacco, MD
T
torqueman2002
SE Michigan
Surplus center has many switches available at reasonable prices. Would either of these work for this application? I did not see the Craftsman hole size listed in the thread. These are similar in size to the Grainger unit listed.
http://www.surpluscenter.com/Electr...ches/SPDT-CO-15-AMP-ROCKER-SWITCH-11-2477.axd
http://www.surpluscenter.com/Electr...witches/SPDT-20-AMP-ROCKER-SWITCH-11-3125.axd
TooMany - Good information. I want to take a more detailed look at the site, to see what they offer.
I did notice that the 2 switches above are single-pole, double-throw (SPDT) center-off maintained. or ON-OFF-ON.
I added additional size information in the 1st post, picture 9.
Great find on these switches.
:thumbup:
6PTsocket
The fact that there are so many interested in replacing this switch should tell you something about the quality of the original switches. I have replaced a couple of Craftsman switches myself.While the original may neatly fit the cutout, that does not change the fact that they were low quality, cheap switches. Even if I could get one, I would not want it. I just find a quality brand that is as big or a little bigger and file a little to make it fit. Making a plate for a toggle switch is good too but a bit more work. Having a gap really looks bad to me.
StillTooManyHobbies
Port Tobacco, MD
Thought I would post my block switch replacement. I had to file my switch opening to about 13/16" x 1 7/16" and it fits and works fine. The switch is a Carling Blodgett 1429R I bought off Ebay for about $12. It can be had for less if you like a blue rocker. It's marked as being good for 3/4hp or 20 amp 250V. It has a nice positive "snap" when it switches. I think it has a nice "vintage" look as installed.
6PTsocket
I used an almost identical Carling switch I got from ebay to replace a bad one on a Sears battery charger. Same color but no ON/OFF, which was good because it is for MANUAL/AUTOMATIC. I had to file a bit, too. I already replaced the one on my grinder. There seems to be a pattern here.
smokey0810
Canyon, Texas
Got my white switch from Grainger installed tonight. Works like a champ!
Had to splice the main wire for the light into the power wire. About 30 min worth of filing to get it just right. Thanks for the help!
Grainger P/N: 2LNA9. $4.08 compared to $12.73 for the red which is 2LNA7
<a href="http://s1265.photobucket.com/user/jearl0810/media/IMG_2149_zpsy2qn29cy.jpg.html" target="_blank"><img src="http://i1265.photobucket.com/albums/jj505/jearl0810/IMG_2149_zpsy2qn29cy.jpg" border="0" alt=" photo IMG_2149_zpsy2qn29cy.jpg"/></a>
T
torqueman2002
SE Michigan
Thanks Smokey!
Good find. :thumbup:
Bogash
Shenandoah Valley, Virginia
Maybe I've missed it in these posts or maybe I'm not as sharp as you all. I have several wires to my switch. One I know is the light, no big deal there. But you all are using 2 pole switches? Can someone explain how there are converting from the cheap (broken!) switch to the 2 pole?? I have a 1/2 horse April 1973 model 397.15591. Thanks in advance!!
T
torqueman2002
SE Michigan
Sears sold bench grinders, Blocks included, for many years.
I am not familiar with 1/2 horse model 397.15591; but I have information on several 1/2-HP m-397.19591. It is a dual voltage 115V/230V model, and uses a DPST power switch.
The Block models in this thread are single voltage models - 115V, and use SPST power switches.
I would post some pictures, but PhotoBucket is not playing nice right now.
T
torqueman2002
SE Michigan
Continued from post #1, above.
Measurements.
Links to each switch and editors recommendations at end.
All switches are rated:
1/2-HP 125-250 VAC
10A-250 VAC
20A-125 VAC
1442 R | BU04225.0002
1514 R | BU01186.0000
Continued in post #23, below.
T
torqueman2002
SE Michigan
Continued from post #22, above.
1148 R | BU01186.1000
I tested each switch, first in the flat-top (ftop) Block.
Flat-top Block
There is a (~1/8") gap, when the PSW is fully seated against the left hand (LH) side of the switch cut-out.
With the PSW centered in the cut-out, there is no noticeable gap.
Outside view.
Inside view.
Continued in post #24, below.
T
torqueman2002
SE Michigan
Continued from post #23, above.
Outside view.
Inside view.
Outside view.
Inside view.
Continued on post #25, below.
T
torqueman2002
SE Michigan
Continued from post #24, above.
Round-top Block
Outside view.
Inside view.
Outside view.
Inside view.
Continued on post #26, below.
T
torqueman2002
SE Michigan
Continued from post #25, above.
Outside view.
Inside view.
Evaluation - None of the 3 power switches are an exact fit; they are (~1/8") narrower than the tested flat top and round top Block grinders.
With the PSW centered in the cut-out, there is no evident gap.
Each PSW was cycled ON/OFF at least 25 times. All of the PSWs have a firm and positive action. The spring clips that hold the PSW in the cut-out, keep the PSW held in place while cycled ON/OFF 25+ times.
To permanently mount the PSW, use 3-4 dabs of epoxy at the back of the PSW/cut-out interface.
Recommendations
Any of the 3 switches are suitable as 'snap-in' replacements for up to and including 1/2-HP Blocks.
You may want to use 3-4 dabs of epoxy to keep the PSW centered.
Best-Buy
1/4" Spade Terminals
Editor's-Choice
Screw Terminals
I like the feel of the switch, it was a bit more positive. Additionally, the screw-on terminals are my preferred motor electrical-connector.
Thanks for looking. :)
Ordering information.
http://www.partstown.com/
BU04225.0002
SWITCH, TGL ON/OFF BLK-SPST
$4.10
BU01186.0000
SWITCH,ON/OFF TOGGLE-BLK
$4.60
BU01186.1000
SWITCH, ON/OFF TOGGLE-BLK 3PK
$13.70
kenc184
Nor Cal
Just had the switch die on my 1/2HP block. I got this replacement from McMaster, cost about $14, it's motor rated, 16A. Had to file a tad vertically, then needed a small square of sheet metal behind to fill the 1/8" gap horizontally. It's a MUCH nicer feeling switch than that God awful OEM thing.
High-Starting-Current Rocker Switch, Wire Leads, Spst-No, Horizontal Line/Circle
7194K53
Left-tilt
Portland, OR
Did you ever get an answer to this question? I bought the two pole switch from Grainger as recommended but I have several wires to connect. If anyone has a diagram or instructions on making a 3 pole, a two pole, that would be great.
T
torqueman2002
SE Michigan
Left,
What model grinder do you have? Pictures of original wiring & switch would be helpful.
You can use Single Pole Single Throw switch above on a Dual Voltage grinder wired up for 115V, but the grinder cannot be used/wired for 230V.
I have several schematics/diagrams of Block wiring. If you post the model number, I will be able to choose the appropriate one.
