Show your new tool arrivals
Viggen337
Maryland
Holy ****, an Eris?! I had one of those ages ago. Does the trackball still work? Mine was a really decent phone and was still working 100% when I retired it, but they had so many problems, ha ha. I still have mine somewhere in my smartphone graveyard...
Keeping this on topic:
I finally got myself a decent compression tester set, along with a great deal on some 1/2" SAE deep impacts from a buddy (didn't really need them, but I liked the case). I also received a set of GearWrench sleeved metric impacts for lug nuts via Amazon. I saw those in this thread a few months back and had to have them. Thanks to whoever posted those! [emoji106]
Sent from my XT1575 using Tapatalk
rednotch
south nj
yes it still works fine, I pretty much only use it as a phone to call people though so I never bothered to upgrade.
dede2897234
Northern, Ohio
Here are some new tool arrivals from the last couple weeks:
Lisle Dual Piston Brake Caliper Compressor (Model# 25750)
I used some of my Sears Shop Your Way reward points to purchase it from Advance Auto Parts' website to get points back. I actually picked it up from a local Carquest Auto Parts. :rolleyes:
Standard Gage 6 Inch Dial Caliper
I used some of my Sears Shop Your Way reward points to purchase it for local pickup. According to Standard Gage's website, it is the middle tier brand in the Hexagon Metrology line up in terms of quality and cost. This dial caliper is made somewhere in Asia.
Megapro Compact Stainless, Magnetic Screwdriver
I used some of my Sears Shop Your Way reward points to purchase it for local pickup. The tip of the screwdriver is magnetic. It comes with 6 bits installed in the extendable cap: 2 Phillips, 2 square, and 2 slotted.
OTC Tubing Bender (Model# 4403)
I purchased this tubing bender at Summit Racing here: LINK. It bends 3/16" and 1/4" outer diameter copper and steel brake lines. It is made in Taiwan.
Gearwrench 3/8" Drive Spark Plug Ratchet Set (Model# 81229)
I used some of my Sears Shop Your Way reward points to purchase it for local pickup. It came with the 84 tooth ratchet, a 5/8" spark plug magnetic socket, and a 13/16" spark plug magnetic socket. The kit is made in Taiwan.
Dave
Viggen337
Maryland
I also got a couple of Proto prybars (top two) to compliment the Proto pry....uh....screwdriver I got from HJE last year.
I didn't know Proto made pry bars like that. I may have to look into those. [emoji481]
I first discovered these at work, where the logistics team uses a few of them: one to clear jams on their cardboard baler, and another to shift pallets on their Crown stacker (no side-shift fork option):
Seems like a waste , they're nice.
AmishFury
Another Frankenratchet, fresh from HF. lol
(My 25" SO ratchet shown for comparison)
now that i know it does in fact work i'm almost tempted...
this arrived today...
atikovi
Suburban Washington DC
Just have to ask, why would anyone still use a dial caliper when a much easier to read and more accurate digital model don't cost much more? Kinda like using a slide rule instead of a calculator.
logikal
Pittsburgh
I prefer using the dial heads. I like the feel of the mechanical action and my old worn in set of mitotuyo calipers just feel great. I have a few of the digital ones but they stay in my box for most of their life.
atikovi
To each his own. I prefer accuracy over feel and my 10+ year old Mitutoyo digital is still spot on and the convenience and speed of viewing a numerical display that can switch from standard to metric is great.
dede2897234
Northern, Ohio
atikovi,
I don't have the bucks or the need to own a Mitutoyo digital caliper. I own a digital caliper that I purchased from Advance Auto Parts several years ago. However, it takes me a few tries to get an accurate reading (first reading is off; second reading is right; third reading is to confirm the second one). This is the reason why I purchased the Standard Gage dial caliper.
Dave
Dave455
Sussex, England
Personally, I have yet to find any electronic Caliper that lasts more than 18 months in an average British workshop! Maybe in a dedicated inspection shop they're fine, but with a few knocks, a bit of damp, metal filings and so on, they just don't last!
My 30 year old Moore and Wright dial caliper has no such problems!
ChevyZ71
Haven't seen my SO driver in a few weeks, but it was well worth the wait. He gave me an offer I couldn't refuse on a service cart, added bonus is that it's green!
Sent from my VS985 4G using Tapatalk
cm_osu
Central Oklahoma
Saw this thing on sale for $35 and had $10 in surprise points. Now just need to find a good deal on a 24".
Sent from my SM-G920V using Tapatalk
stonesfan68
Houston, TX
You're making the assumption that digital is more accurate than analog. This is sometimes true and sometimes not.
MattVette89
SW Chicago
After the positive reviews, I picked up the HF ultrasonic cleaner to do some small carbs and whatnot. Used it on two carbs this morning. Still didn't replace a manual cleaning of some of the passages, but I think it did a nice job. That could be related to the cleaner I used. I still need to experiment a bit.
rice rocket
I found that it really depends on the orientation of the part. I use my for bicycle parts, but I'll usually run it at least twice per part, flipping it for the second cycle.
MattVette89
SW Chicago
I ran three eight minute cycles and flipped the carb around each time. I was still happy with the results. I will try simple green next time.
VCaddy
Las Vegas
Acme Tools had a nice promotion going on Milwaukee today. 15% off everything, plus an extra free XC 5.0 battery (not pictured) with the impact kit.
K-Dog
Millersville Maryland
Okay so, its not really not MY new tool. The shop bought it cause the old welder took a dump on us.
I might be breaking it in later this week if not some time next week.
AA/FC
I have the same machine from HF. I was absolutely blown away at how well it worked on several small engine carbs that I did. I ran each carb several full length cycles (maybe 6 or 8 cycles) and flipping the parts each time. I really think the key to excellent cleaning is a combination of.... heat/ultrasonic/cleaning solvent. They are all equally important. However, the hotter it gets, the better it seems to work. (obviously) If you don't want to run as many cycles, just wait for it to get hot before starting.
I used Krud Kutter from Home depot and it worked fine. (Saw a guy on youtube using it on carbs) I will try Simple Green next time.
Anyway, the carbs I did came out looking brand new and functioned great!
