Bevis
At the point of running my conduit from Hose panel to the shop sub panel. I need to run my conduit thru the block wall to connect to the house panel. What's the best way to get thru the block wall?
If the block is filled, there's a good chance you'll encounter a stick of rebar in the center of the core, which cannot be drilled though.
Yes it can, it just takes a good core bit and a good drill.
Sounds like the OP got it all set; and coring through concrete is fun.![]()
