Block Wall
Bevis
Moore Haven, Florida
At the point of running my conduit from Hose panel to the shop sub panel. I need to run my conduit thru the block wall to connect to the house panel. What's the best way to get thru the block wall?
rinny_tin_tin
Northern Virginia
A_Pmech
IL
OK, good. Filled block responds much better to hammer drilling than hollow block.
I would run the conduit though the center of a block, rather than through a core. If the block is filled, there's a good chance you'll encounter a stick of rebar in the center of the core, which cannot be drilled though.
Use a core bit mounted in a hammer drill. Size it about 1/2" to 3/4" dia. larger than the OD of your conduit.
Start by drilling a pilot hole though the wall SMALLER than the pilot bit of the core drill right though the web of a block. Then, start a core bit of suitable size on the pilot. Every few inches you'll have to pull the core bit and break out the core with a chisel. About half to 3/4's of the way though, withdraw the core bit and start from the other side. This way, you'll avoid a huge spalling breakout where the bit exits the wall.
Once though, install your conduit. When your electrical installation is done, grout the conduit though the wall using gray polymer fortified grout and a grout bag. You're done!
A_Pmech
IL
Alternatively to the pilot hole, you can extend the pilot bit of most core drills several inches past the face of the core drill. Run it until the pilot drill just makes it though the other side of the wall. :thumbup:
dipper
Rochester, NY
Yes it can, it just takes a good core bit and a good drill.
Sounds like the OP got it all set; and coring through concrete is fun. :)
A_Pmech
IL
With a diamond core drill, yes.
Not with a carbide hammer-type core drill.
My Hilti hammer-type core drills have specific language on the packaging that prohibits the drilling of re-bar. Just hitting a stick can be enough to chip the carbide and destroy the tool. ($250 and up)
Hitting a stick of rebar stops the progress and chews up your tool.
