Baldor grinder
1930
Florida
A few months back I restored this grinder/stand and like the ******* I am lost one of the disks that hold the wire wheel/grinding wheel onto the output shaft. Its 3 1/4 diam and shaft is 5/8.
Id like to find the missing part, I know that I could make something work but not interested in going that route.
Im hoping some of you hoarders ( I mean collectors of fine art ) can help me to get this machine back into use using the right part.
Let me know what I need to do to make this happen, thanks.
rsanter
visalia ca
I think you can get them off amazon as well
They are a generic part, you just need to get the one with the right diameter and hole size
Bob
torqueman2002
SE Michigan
Bob
+1
My Baldor flanges are notched, to clear a roll-pin, that locates them on the arbor/shaft.
You can also find other pieces for your grinder, for safe operation>
  • spark arresters
  • tools rests
  • eye shields
  • wheel guard covers
  • replacement stones
The stone looks like it has been used for grinding non-ferrous metal (aluminum), which can cause the stone to explode.
See the 1st link in my signature line for more Safe Grinding guidelines.
:thumbup:
1930
Florida
+1
  • spark arresters
  • tools rests
  • eye shields
:thumbup:
Why would the stone explode?
torqueman2002
SE Michigan
Basically, the pours of the grinding wheel become clogged with the softer non-ferrous metal, then over heat when pressure is increased to over come the loss of efficiency the bonding material fails and the wheel comes apart.
Even if pure, non-ferrous aluminum is used, sparks can occur during an aluminothermic reaction, also called a thermic reaction. Such a reaction occurs when an aluminum particle and a metal oxide, such as rust, are ignited by a heat source and chemically burn as a "Class D" fire (i.e., combustible metal). The reaction is similar to a fireworks explosion, can create 4,500ºF sparks, and can occur when a grinder is used on ferric material (e.g., steel) ...
We've all done it and gotten away with it, but since I've frequented the Block grinder thread I have stopped.
More reading:
https://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=INTERPRETATIONS&p_id=27413
http://www.garagejournal.com/forum/showpost.php?p=5175492&postcount=6976
http://www.practicalmachinist.com/vb/general-archive/bench-grinder-aluminum-73038/
Sign I use as a reminder, at the ferrous grinder station.
1930
Florida
More reading:
I have seen that sign in various shops and now it makes sense, thanks
torqueman2002
SE Michigan
