PermaBilt - Electrical Plan
bmxdad
Puyallup, WA
If I flipped it, it would just cover the neutral bar, but it is longer ... hmmm.
And yes, the white clip on the top left of main breaker is the retainer. and it looks like it will work either side. That is the factory location for the main too.
bmxdad
Puyallup, WA
Added some new lighting and updated the panel, along with adding a new 15 amp breaker (bottom).
View media item 44028
There are 5 fixtures, with each pulling 2 amps for a total of 10 amps. That's only 66% of total available amps, so were good.
bmxdad
Puyallup, WA
Thinking about the following circuits:
  • Four 240v circuits
    • Overhead Heater - 40 amp
    • Air Compressor - 30 amp
    • Plug for welder - 30 amp
    • Hot water heater - 20 amp
  • Two lighting
    • One for two light fixtures
    • One for four light fixtures
  • Three wall plug - one for each wall
  • One Door opener
Just going over the old plan to see how far off I was ...
So far:
    • Overhead Heater - 30 amp - done
    • Air Compressor - 30 amp - in work
    • Plug for welder - 40 amp - done
    • Plug for water heater - 30 amp - waiting
  • One for lighting - 15 amp - done
    • One switch for two light fixtures
    • One switch for three light fixtures
  • Five wall plugs - 20 amp, near wall - done.
  • Two wall plugs - 20amp, back wall - waiting
  • Six wall plugs - 20 amp, far wall - done
  • Garage door opener - 15 amp - done
bmxdad
Puyallup, WA
Just an update on panel work ... Bold is new
    • Overhead Heater - 30 amp - done.
    • Air Compressor - 30 amp - done.
    • Plug for welder - 40 amp - done.
  • One for lighting - 15 amp - done.
    • One switch for two light fixtures.
    • One switch for three light fixtures.
  • Two wall plugs - 20amp, back wall - done.
  • Five wall plugs - 20 amp, far wall - done.
  • Two wall plugs and an outside plug - 20 amp, panel wall - done.
  • Rear outdoor lights - 15 amp - done.
  • Side outdoor lights - 15 amp - done.
  • Rear outdoor plug - 20 amp - IW.
  • 240v 30 amp off panel - IW.
bmxdad
Puyallup, WA
One year later ...bold is newish.
  • Three 240v circuits
    • Outlet for welder - 40 amp - done.
  • Five wall outlets - 20 amp, near wall - done.
  • Two wall outlets - 20amp, back wall - done.
  • Five wall outlets - 20 amp, far wall - done.
  • Two wall outlets and an outside outlet - 20 amp, panel wall - done.
  • Garage door opener - 15 amp - done.
  • Rear outdoor outlet- 20 amp - done.
  • Front outdoor outlet - 20 amp - done.
  • Overhead LED lighting over Shop bench - done.
  • 240v 30 amp off panel outlet - IW.
Norcal
The hold down is installed on the main breaker. I would have flipped the panel so the main was at the bottom to make it easier to wire by minimizing the feeder conductors in the panel.
bmxdad
Puyallup, WA
Agreed. It didn't become an issue till a few breakers were installed. I can't flip the panel, but can flip the breaker pan, and put the main at the bottom, which would open up the grounding lug ... one day.
Norcal
You might have to flip the pan on the panel front also if the interior is flipped.
bmxdad
Puyallup, WA
Wonder if I could just move the main to the bottom. I'd need to drill a hold down for the lock though. Would be the simplest to do .... hmmmm.
Norcal
Take a lot longer to drill & tap for the hold down bracket & that would be making mods that I would not be comfortable doing, the interior swap is a lot quicker.
