All_Bavarian_Garage
- Joined
- Sep 4, 2015
- Messages
- 23
***UPDATE***
Hey all,
So I talked to the owner of the company about what happened. To make a long story short, he came back out with the same 2 installers and installed another anchor in the same area that failed.
This time making sure to blow out any and all debris in the hole.
We dropped the anchor in again, and it went right to the bottom. (I verified with a Powers engineer that this is typical when using a brand new drill bit)
It took around 10 good hammer blows to easily set the anchor. Verified by the blue paint on the top of the anchor being removed.
And the result? No cracks!
The owner agreed the reason the anchors did not set all the way was because of the dust from drilling left in the hole. When they did not fully set, the installers hammered harder and harder on them until the concrete failed.
So he said they will do a pad for me at that spot for free. I wish the installers would have been less half-assed and more detail oriented. I hired them for their expertise in lift installations and not just for manual labor.
Anyways, I could have been working on my track car, but instead now I get to wait for concrete to dry. Yay
(Uploaded a new picture showing the new anchor and no cracks connecting to either of the holes next to it)
original post
During install of my 2 post lift today, I observed cracking that propagated from each of the anchor holes while the Power's 3/4 anchors were being set. (using the proper setting tool)
It took a lot of hard hits and the installers were still not able to seat the setting tool against the top of the anchor to remove the blue paint (per instructions included with the anchors).
A test hole was drilled prior to the install and they drilled 6 inches deep and did not get through the slab. The previous owner told me it was 8 inches thick.
The installers said they could not continue the install and that I would need footers to be poured.
I am quite surprised to find out that the concrete was not 3000psi rated?? For an 8 inch thick slab of concrete in the garage?? House was built in 1997.
Please post your thoughts on the concrete.
**One point of major concern is: How close can I pour a footer to the side wall of the garage?
As you can see in the picture, I had the base plate about 3 inches away from the wall. This gave me 3.5 feet of space to work on that side of the car, which I thought was enough. It also allowed me to park another car in the garage with the lift in place. Is it possible to pour the footer right next to the wall?
Hey all,
original post
