I like the Mac AWP050/Proto J150WP personally.
Might want to check out the Proto J150WP. It's the same exact gun as the Mac (minus the shroud around the trigger) and can be had for under $300. I've been using it since it came out a couple of years ago and it's a great gun. The internals are all interchangeable with the Mac and while the Mac guy probably won't service it, you can get parts/service at any Dewalt Service Center.
I absolutely love the Ingersoll Ti guns. They'll go around 3 years of professional use in many cases of properly oiled and greased up front (most guys never grease the front end) from what I've seen.
I just hate the balance and height of the MG725. Yes, as everyone always mentions, it's nose heavy. But more than that, look at the design of the gun. The motor and the upper housing are almost an inch higher because the top of the grip is lower relative to it - the design adds some height between grip and upper, giving all that weight up top more leverage on your wrist.
well I'm now the owner of the Mac AWP050 Mac guy done a top deal n threw in a protective cover some oil and few other freebies. Hopefully it stands the test of time.
I wouldn't buy a gun based on your driver. They typically don't repair thems anyways and still have to send them off. Might as well get the gun you want if it has to be sent out for repairs.
Enjoy your new impact.
IR holds the crown for power but all the top tier impacts are still within 10% (or less) of eachother. ......
Reliability wise MG725 probably wont go decades like the other two due to the "oil bath" design.
MG725 and IR2135 and 2235 are mostly made in the USA.
MG725 does sound coolest though. Without the muffler it will blow your eardrums out.
IR if buying new.
