It's a tool, What is it ?
Elroy
kentucky
What is it.
Actually a better question would be: What are these magnets used for?
Like any thing else. If you have used them before the answer is simple.
sk farmer
nd
cattle magnets. pieces of barb wire, scrap iron or other metal can be ingested by animals. this can irritate or perforate the digestive system of an animal. stick a magnet down their throat with a balling gun and hopefully problem solved and animal saved. great in theory but does not always work. death or invasive surgery are not the best end results.
Art From De Leon
De Leon, Texas
I believe they are 'cow magnets'
http://en.wikipedia.org/wiki/Cow_magnet
You get it down the throat by using a balling gun, and it will attract trash metal that is found in the feed.
We would use them inside the suction screen to catch metal residue from worn parts in the common oil sump, that would harm the hydralic pumps, valve bodies, etc, if allowed to circulate through the system after repairs were made.
sk farmer
nd
i think we are on the same page art. always a pleasure to help elroy, the least we can do for one of our finest.
hydramatic
Alabama
in the 70`s they claimed cow magnets on your fuel line going to the carb, gave the fuel positive ions and increased fuel milage...bruell sheet !!!!!
E
Elroy
kentucky
cattle magnets
I believe they are 'cow magnets'.
Fully accurate and prompt response. :thumbup:
Elroy is impressed :bowdown:
We thought that one might take a little longer than 15 minutes. But NO.
Here is another, but this one is cheating a little:
So what the hell is it??
Hopefully this one will take longer than 15 minutes.
E
Elroy
kentucky
It's an automotive part found in most cars today. When Elroy was in the machine design field he developed a high speed assembly procedure to place..........
oops, getting ahead of the story.
E
Elroy
kentucky
hmmm.... Is it some sort of position sensor?
-BWP
It's actually a bearing. Now the question becomes where is it used??
The seat maybe?
Window regulator?
Anti-Lock Brakes?
Brake peddle support?
Air bag?
Sway Bar?
Trunk Latch?
none of these.
E
Elroy
kentucky
Elroy developed the assembly equipment for the Wynn's-Precision plant in Springfield, Kentucky about 1998 or so.
Elroy was 13 at the time :wtf:
Dmaxman
Montreal, Canada
Looks kinda like Glyptal paint on it....makes me think its for electrical with that ceramic or porcelain or just plastic?
E
Elroy
kentucky
The white body is 1.290" in diameter x 1" tall. The brown insert is a Teflon faced bearing.
It supports the rack gear in a steering gear.
bgott
Houston, TX.
You know, I remember those now. I took a power rack and pinion steering gear rebuilding course in about 1985 when I worked at a Chrysler dealership. And have never had a reason to tear one down since.
