Coating 3yr old concrete in my shop....problems?
IQRaceworks
SW Missouri
I poured the floor in my shop about 3 years ago. At the time I didn't want to mess with coating the floor with anything. It's still relitivily clean, but I've got a few spots here and there where or or grease has got on the floor. Can I go back and coat the floor now, or is it going to be a pain in the ****? What will I need to clean the concrete with?
Also, what's something that is easy to apply but will stand up to the abuse of pulling boat trailers and cars/trucks around on the floor without pulling the coating up or wrinkling it up?
Any advice would be great. Oh, the shop is 30'x40'.
Thanks
benwah
Lakewood, Colorado
You would need to de-grease the floor. There are a number of products on the market that can get this done.
Afterwards, I always suggest grinding your concrete before applying coatings. This insures adhesion (bonding) of the coating to your concrete floor. There are a number of systems you can go with. A very common and proven system is epoxy / urethane. If you do a quick search on the forum you will find a plethora of information.
Garage Flooring
Grand Junction, CO
Thanks
ABSOLUTELY what Benwah said. Then you can decide if you want a sealer or an epoxy. If you want a sealer you will do a much finer grind.
