The VISES of Garage Journal
AnotherJarhead
No one answered AnotherJarhead's question about the 600s and the 800s.---I'd like to know too.---Has anyone ever seen a 500 or 400 with that configuration?:dunno:
Thanks for the bump Grouseman. Sometimes I feel like a redheaded stepchild at a family reunion on this forum. lol
joe.striper
agawam, ma
I only post these pics of the Wilton 3 and 4.5 bullets I just finished as a defense againt Veeps most excellent 4" which he ridiculously over restored.
sandman54
Ft Worth Texas
ALL: great stuff today. much better than the usual price talking. i agree that the older vises like Prentiss might also have had the back slides cracked because the users were used to a blacksmith vise or a user of one thinking the new designs could get pounded on. it might have had a weak point in the Prentiss design, but betting all those cracks were from a BFH and user. we have many members of GJ that almost come to blows and name calling if I (we) mention that a vise was designed as a third hand and not something to be pounded on. as i've said when i was a wee lad i would go with my Gramps to the logging equipment repair shops and see a worker putting a 3 or 4 foot piece of pipe on a vise's handle and putting all his weight on it to tighten something in the vise and beat the **** out of it. a bench vise IS NOT a blacksmith vise.
not sure why Columbian isn't in my top 5 or maybe 10 because they are nice vises. i even have passed on some with the old round type handles that are similar to Rock Island and Reeds. maybe Columbian and Wilton are not my favorites because they make cheap vises too unlike Reed, Prentiss, Athol (Starrett), Rock Island.
I'm still learning to speak "METAL" and really like what's been said today. thanks
Isaiah: nice find on the York and it was probably copied by Wilton and made into maybe the most recognized vise in the world then and now. I'm guessing the hole in the back of the vise is for a pin that should hold the vise nut in place sort of like the design for the old Leinen German vices. since i don't own a York (yet) maybe one of the other guys can say.
Bagged: your vise restorations have been great so far so if you think the belt sander can give you something better then good luck with that. :thumbup:
hey drives simple put a lot of people abuse their tools and vises!
va.grouseman
Southern-Central VA.
Veeps, make your knobs this way, you do not need a radius cutter, just a angle grinder with a sanding disc. I drill and ream a nominal sized pilot hole in the knob that slips over a machined step on the handle ends. .001 clearance is a fit I like. I use a 36 grit sanding disc backed up by a plastic pad. You can get very close doing it this way. Then go to a Hook and Loop Nylon Mesh pads http://www.mcmaster.com/#46555a58/=1098yll then I follow up by filing the heavy scratches out and use 100 grit sandpaper to smooth out the filing marks. Finish up by using the red Scotch Brite pads. You go further in the finish then me. Add a chamfer so you can peen it to the handle. After a couple they get real easy.
Beautiful work KM.
You have that MacGyver/Marine mentality.---Improvise, adapt, and overcome.
kcrccc05
A few days ago I asked for help to id a vise with no visible markings -one of the reply was Howard Iron Works -I gave it a good cleaning and found on one of the jaws printed no.2 Parker Meriden CT -has anyone ever seen identification printed on jaw insert ?
GETRIDAONE
Auburn, GA
Seems that Ganymede was correct in that Parker used the top screw for the collar at one time. I guess the conclusion is that Parker branded the vises for Howard Iron.
Rileysan
Milwaukie, Oregon
View media item 55666
Is this a good price on this anvil? Found on Craigslist Portland Oregon.
:dunno:
I've been looking at this posting off and on for months. I don't know enough about anvils to make an intelligent comment, so I'll defer on its value. However, I wouldn't touch it for that price - and based on how it's been listed and relisted, I'd say most everyone else feels the same.
Brian
topop101
NW Missouri
Brian
It is a bit high ...At least for my area. 3 bucks a pound for a high quality anvil and that one is. Plus the stand so...
KMScott
Here is some Parker stuff kind of interesting. Note the copper caps and the widths they made which means all the jaw widths they made and the steel bar they cast into the square slide. Not to many Parker's have cracked slides like the Prentiss's, I wonder if this bar helps that issue. Got a kick out of throwing a 29X out of a airplane to test it's strength.
Oldie, yep plenty of snow, two hours of plowing Monday and then the wind shows up to push it where you don't want it. Shop is 45 degrees till noon then it warms up to 55. Just about used to it again.
kcrccc05
KMSCOTT -what models would be the Victor series Parker ? -also can you check my last post regarding the Howard iron /Parker stamped vise jaws ,like to know your opinion -thanks
FMC1959
Montreal, Canada / Upstate NY
AJH &VA, I can't recall any 400 or 500 series with the through bolt holding the jaws. But I definitely have see the C3 use the jaw configuration on some older models.
http://www.google.ca/search?q=wilto...ved=0ahUKEwiVkOPfleLJAhWkuYMKHZiGAM8Q_AUIBygB
A simple Google search for "Wilton C3 vise" and then clicking images gives the above result. You can see the red one, 3rd or 4th row down is pretty old, Schiller Park
va.grouseman
Yea FMC, You are right about the C3s.---You can rarely check the Wiltons on EBay without seeing a C3 with the indented jaws.---I like that style better than the newer ones.
KMScott
Sorry, I wish I was more up on the history of Parker's. My time is spent on the mechanics of these vises and making the parts to put some back together. I posted these articles after seeing your post yesterday thinking someone might offer information on your vise. Customers send me pictures and interesting articles that I share. Very nice vise you have and interesting to see the stamp no.2 Parker Meriden CT on the jaw tops. Shows how much your vise has not been used.
Shiftless
East Bay SFO
Finished this this up for a buddy's Christmas present I think he will be happy!
Beautiful job, Loydski!
If your buddy isn't happy with THAT biggie, something is wrong with him.
If he would rather have a much smaller vise with battle scars, tell him I'd be happy to trade! :)
bagged89s10
CT
The Wilton 840 finished. New handle made from 1144 stressproof rod. New jaws from Kevin Scott. Polished main screw nose and rear dust cap. Smooth anvil surface and jaw towers. Hammerite light blue paint. I had to make a new swivel base center pin and the dynamic jaw was sagging a little and had some slop. To fix the problem, I removed the keyway and sandwiched in some shim stock to take up any play. It lines up almost perfect and opens and closes perfectly without any side to side slop. I'm really happy with this one and got to learn how to make a handle in the process.
Before
The new jaws from KMScott
The new pin
The complete product
The buyer picked it up and the he and the vise should be on a plane to Belgium right now to deliver it to his father for Christmas. I hope I get cool Christmas presents like this from my son when I'm older.:thumbup:
s1196.photobucket.com/user/ProperDesigns/library/Wilton 840 restore date stamp 1946?sort=3&page=1
Jcrapola
North of Detroit
WOW!!!
Loydski, that is awesome! Love The Flag on the post! I hope some of my buddies view this thread and want to make something that cool for me!!!
Bagged, That is abso-FLIPPIN-lutely amazing! Post it in the Vise of the year thread! That thing came out Killer!
I have been restoring one for my Pops for Xmas. But after the works of art you guys just posted. I am embarrassed to put mine up!! Both of you KILLED it!
topop101
NW Missouri
Before
The new pin
http://i1196.photobucket.com/albums...1946/AB292174-7079-4C43-A1DF-064CC13724D0.jpg
Excellent Bagged.!The main screw knob turned out amazing! How did you get all the pitting out?
Hemi49
Rush (Rochester), NY
Before
The new pin
BAGGED
Beautiful job on the 840:thumbup:.....
Hemi
rmalkow2
Brighton, MI
Bagged,
What an awesome job on the Wilton. I really like the combination of bare metal finishing with some polished and some the brushed look. Paint cam out fantastic.
Evergreentree
Montgomery County PA
Beautiful bagged! Great work!
I'd like to put jaw covers on my little Athol 2 1/2". Anyone use aluminum jaw covers? I was also thinking brass. Really, I just want something to protect the jaws on the vise. What's the opinion brass vs aluminum?
KMScott
Real nice job, your buddy will enjoy your work in his life time and then pass it on.
Veeps you got the touch. Whats next...
Using the keyway as a riser is an original idea. Again top notch restore. You are stepping up the quality of restorations being shown here.
bagged89s10
CT
Wow bagged! Just WOW!!
Thanks CRS
No wonder Joe was crying so much. That one is is over the top !!!
Thanks, I just saw what he posted yesterday. Lol
Bagged that Wilton looks amazing! Awesome work!
Thanks You
WOW!!!
Thanks, I posted 2 of my favorite personal restorations.
Bagged, totally awesome. Your skills are growing with leaps & bounds each vise you do.
You should get the "Master Vise-Smith" award for 2015 :thumbup:
Thanks FMC. I'm learning as I go. I'm far from a master.
Thanks topop. I put it on the lathe and took a grinder to it, then smoothed it out on the belt sander. Then did final cleanup on the lathe.
BAGGED
Hemi
Thanks
Bagged,
Thanks. I like the way it came out to. I was going to polish the jaws at first, but the hardened jaws would have taken ages to sand smooth.
bagged89s10,
Magnificent work! Well done.:)
Thanks. It will be calling home on your side of the pond in Belgium
Thanks evergreen. I also want to make some jaw covers for my Parker vises. I wonder if I can find some copper somewhere
Thanks Kevin. Your jaws added the final touch. And boy are they hard! And they fit perfect!
Next is a Columbian 203-1/2. Do you make these T style jaws?
