kartracer55
- Joined
- Jun 21, 2005
- Messages
- 5,317
Is there an easy way to calculate how torsion affects torque being transfered on a long hex socket?
Heres the situation... I need to torque 5 socket cap screws to 95 inch lbs. There are two methods to do this, one involving a standard hex socket, the other with a long hex socket. To use the standard hex socket means quite a bit more work in this process, and the time adds up because these screws are replaced and retorqued quite often.
As I go to torque these screws, I can see the hex stock actually twisting on me, and im guessing this is somehow affecting the torque being transfered through. So is there an easy way for me to calculate how much torque is actually being lost because of it? When I am home I can do it the correct way with the standard hex socket, but at the track I simply dont have the time to go through all this so I would like to know if, instead of setting the torque wrench to 95 in/lbs, I can set it to 95+X in/lbs to compensate for anything being lost through the long socket.
Also, If anybody could help me understand something a bit better it would be great... Is this length of hex stock in the socket absorbing a certain percentage of the torque proportionally as applied torque is increased? Along those same lines, is there a point where this begins to happen or does it only become more apparant at higher loads? Or, does it reach a certain point where it simply cant transfer anymore torque and begins to twist like this?
Thanks
Jim
Thanks
Jim
