Got a bit of an odd situation here. To start things off, I rotated my tires when I changed the oil last, only about a month ago. Rears came up to the front and fronts back to the rears but crossed over.
Today, I get in my car to go to the store only to find that somehow my front right tire has gone totally flat. I don't really know how it happened the car drove fine a couple days prior.
Anyhow, at least this happened in my garage and not on the side of the road somewhere, and on the weekend and not when I need to drive to work. I swap the flat out for my spare and take the flat tire to Costco where I got the tires from. After looking at it they call and tell me the tire is not repairable (puncture was on the side I guess) and it has to be replaced. Well, it seems they don't make the exact model of tire I have on there anymore and supposedly they can't just swap out one tire they have to do it in pairs, so long story short I end up with 2 brand new tires and $7.50 in my pocket (yes, somehow through the warranty and exchange for the new tires, they owed me money).
Now onto my question: when they put the two new tires on, they put them on the rears and put the rear tires on the front because I guess that's what they do when replacing less than a full set of tires. So, if you are following along the tires on the front of the car now are the same tires that had been on the front before I rotated them. In effect my previous rotation has been undone.
So I want to ask, should I rotate the tires again, and put the old tires back on the rear of the car where they were before I had the flat? I'm just thinking I rotated the tires because the front tires had already been in the front for 6k miles, and now they are back on the front where they will be another 6k miles before I rotate them again, and if you simply exclude the fact that the rear tires are now brand new, the current tires on the front will have been there for 12k miles before being rotated again. Is there any real reason to put new tires on the rear? I figure the rear is where the tires wear the least (at least on a FWD car which this is) so why put the newest tires there?
In the end it probably does not matter much either way but I thought I would see what you guys think.
Thanks
Ruahrc
Thanks
Ruahrc
