Micro Knipex to small ?
dogdad
Down south
Do those that have the Knipex micro(86 03 125 ..5") plier wrench find it to small and wish you would have jumped up to the "6" (83 03 150 )size . I've ordered the 7" and 10" ,,looking to add a smaller size for now....
jallyn
Fort Wayne, Indiana
I almost got the 5" Cobras when I saw it in the mini set with the 6" Pliers Wrench. But since I couldn't actually see myself wearing the belt pouch I just bought 6" Pliers Wrench and 6" Cobras separately. Both are small enough to still fit in a pocket. And the the 6" Cobras give me 20% more power/range over the 5" size (same math applies to Pliers Wrench).
If I need a really small adjustable wrench I use my ChannelLock 804 which is the 4" size (actually 4-1/2" tip-to-tip). They are made by Irega in Spain, re-branded for ChannelLock, and are quite nice, though pricey, for a 4" adjustable. At the plant I work at there was a square head bolt in a tight spot I couldn't get my 6" Pliers Wrench on. So I put my ChannelLock 4" adjustable on it, and used the 6" Pliers Wrench as a cheater so they were both pretty handy.
Fxsb103
Mohnton, PA, USA
If i didn't have my channel locks, YES.
I started with the 6" dikes as an electrician. Had to need to go to the 8". I had the needle nose with the built in strippers (and had them taken at a job) but liked them so much I will replace them. I have the 5" cobra pliers and use them for tight locations. Otherwise I use my channel locks 10" or larger. I do love the quality and will save up for a set of larger knipex pliers since everything else is chinese.
honcho
Near Sodom & Gommorah (aka Wash. DC)
Since you can't take tools longer than 7 inches on airplanes in the USA, smaller versions of various tools, while limited in their utility, are useful for some members of the air-traveling public
danwolfgang
CT
I bought a 5" pliers wrench for the head size -- 4mm wide? Something like that. The length is too short, IMO. If I could get a 7" long pliers wrench with that tiny head, that's what I would have bought. Look at the head size when you pick which to buy.
geojag
Little Rock, AR
I use the 6" pliers wrench daily, sometimes at min. capacity and sometimes at almost max. capacity. It handles 99% of what I need it for. It all depends on what sizes of fasteners/fittings you work with.
KTMrider
I carry the 6" mostly. Tool bag for working on this out on the trails.
shamrock12
South Dakota
I wish Knipex would make 8" Cobra too.
Then the 6" Cobra would be a good step down size rather than 7"
Since that is not the case, I have 5" Cobra as a step down from 7" which seems rather small to me.
