OIL Filter Wrench, looking for a veritical one, not horizontal
old&fat
I have a Toyota Tacoma 2004 and I am sick and tired of trying to put a long rigid horizontal tool on a part in an area that is a vertical area to get to, basically, if you get my drift.
Where can I buy a oil wrench that is shaped like a Y, so to speak, and goes up and around the bottom of the oil filter and then tights and you can spin off the filter.
Trying to make my life easier, any suggestions, brand names, thanks in advance.
Bighead38
Rockland County NY
What about one of the cup filter wrenches? Put a long extension in and drop straight down.
Might be called oil filter socket or oil filter wrench. Not sure on the correct name but looks like this:
http://m.summitracing.com/parts/lil...bC-WL6JXsGchPKwrwcYGreM2jdllfB1SmAaAmAY8P8HAQ
They work really well on certain vehicles but are a pain in the *** to get off the filter in my opinion.
This one fits 05-07 Tacoma with v6.
http://www.amazon.com/dp/B00239WHLG/?tag=atomicindus08-20
I don't know what size the filter is on your 04 but they should make the socket for that filter size. Hopefully this helps. Good luck.
PoorOwner
CA
I know it is sort of expensive but get the Assenmacher one, as far as I know on the bigger Toyota filters (90915-yzzd1 2 3) it is sort of unique in size and flutes and only the assenmacher tool fits.
I have also used this kind of filter attachment on this Toyota filter, if this above picture is like your truck it should work, but not as nice as the correct cap. Previously burning my hands trying to slip this little guy down to the block of the 2JZ engine
AmishFury
i'm assuming you mean the filter is vertical... multiple options exist... if you see yourself always using the same brand of filter on the truck a cap style wrench with an extension will be the best... find a cap that fits your filter really well and stick with it
otherwise you can try one of the clamping style filter wrenches that use either the claw style with the 3 arms or the one someone else linked
lightning02
if your going to buy the cap style make sure its made out of some type of metal/alum/stainless. basicly nothing plastic.
i use the cap style.
Fender1325
Im not familiar with tacoma's oil filter location, but I usually use a large pair of channel locks. Just open it up and grab tight on the filter and slowly twist.
gungatim
west mich
there is also the regular metal strap type except in place of the handle there is a female 3/8 or 1/2" spot for an extention/ratchet. used to use those all the time on small blocks where the exhaust was close to the filter. still available at the parts stores AFAIK. cup wrenches we used to beat on and off with the ratchet else they slip with any oil on them...
attached pic is one made by KD
bart1
Alabama the Beautiful
I have a Hazet one that looks just like this for my Porsche 993 second filter, which I assure you is about as difficult a filter location as you will find.
For my Scion FRS, which may us the same filter flutes and diameter as yours, I have not found a socket type one yet. I have a small set (9") of Channellock oil filter pliers I use for removal of it.
http://www.amazon.com/dp/B0009WG5SU/?tag=atomicindus08-20
Also have one of the ones pictured by anndel, mine is branded Craftsman and I think they are all the same. That will remove anything, though it's finicky to use and may damage the filter.
The second one pictured by PoorOwner is one I always thought was a good design and wanted to try. I think Lisle makes them.
toolmutt
Texas
I have a metal cap for my F150 but have used a plastic one (don't remember the brand) for my Tahoe for 10 years with no issues. Just make sure it has a metal insert where the drive tool attaches.
JBradley500
I'm a fan of the nylon strap wrenches. They're cheap and useful for various vehicles.
djb2
Redwood forests
I have a surprising number of oil filter removal tools, despite now having only vehicles with cartridge filters.
The rotating clamp type pictured above will remove almost any filter, but they have a drawback: they will release the filter as soon as you release the torque. I usually only pull one out for a stubborn filter.
The cap style is most convenient. If the cap fits correctly you can remove filters buried sideways under hot manifolds without getting oily or burnt. You do need one that matches the number of flutes/facets/flats on the filter. Some caps nominally handle two different facet counts, but they don't work as well as a cap that handles e.g. only 14 flats.
Gila Monster
At least on mine, the Toyota has a unique size when it comes to those "cup" sockets.
I have a whole adapter set, and for whatever reason, none of them properly fit the Toyota filter.
Steve_P
The two jaw Lisle one is awesome, made in USA, and priced right. I have both sizes they offer. I have a 2009 Tacoma, this is what you want IMO.
lakeroadster
Central Colorado
I'm pretty sure you can buy the filter wrench at your local Toyota parts department.
I have a 2002 Tacoma, and use a cup style wrench, looks just like the one previously posted:
zkling
:+1: for the 3 jaw gripper version. My craftsman has saved the day many a times.
impactsocket
I have the Craftsman 3 finger oil filter wrench and there is a lot of play. It will also slip off my extensions. I would buy the Lisle oil filter wrench instead of the 3 finger oil filter wrenchs.
spin_prod_208523001
'52Chevy
SW Idaho
+1 I have the Craftsman 3 finger and love it. works for everything. Its almost too big for my Subaru filter(has a really small filter) but goes very large as well. It does take some getting used to but overall it's well worth it.
alfazer
N. Ireland
I've changed the cartridge filter on a 2.0 d4d diesel Toyota and had to buy a end cap type wrench. Nothing else, including the three legged type would fit because the filter sits up inside a housing with no room for anything to grip the filter sides. Similar is a BMW motorcycle I used to own.
Whole sets of cap wrenches in different sizes are available and probably a good investment for the future. Don't know if the sets are available in good brand names, but the cheap ones I've used seem OK.
mrvm
PA
I got this cam action oil filter wrench by OEM as a filler item to reach the minimum purchase for free shipping. Have not used it yet since I have plenty of options to remove an oil filter. Nice place for deals on Knipex or other tools. Check out the clearance section for better than HF filler item prices
http://mobiledistributorsupply.com/import-oil-filter-wrench-1.html
Part number: 25128
The OEMTOOLS Cam Action Oil Filter Wrench fits oil filters 2-1/2 in to 3-1/8 inches and is fast and easy to use with a 3/8 in drive ratchet. The extra range of the import car filter wrench enables the wrench to fit almost all import car filters and the more common 3 inch domestic car filters.
Fits Oil Filters 2-1/2 in to 3-1/8 in (63.5mm to 79.4mm)
3/8 in Drive
For Removal of Oil Filters Only
Tatsuya
Seattle, WA
I have this from Snap On over 15 years.
It's now Blue Point
I have the Craftsman version of this. I absolutely hate using it, but I've ended up using it quite a bit. The filter cap types are way better. If I were a mechanic or a lube tech I would just buy a whole set of those.
OHMS LAW
Houston TX
Oil filter pliers are my go to. Also oil filters should never be more than hand tight. I hate when they are cranked all the way down. Like really????
OHMS LAW
Houston TX
Also I have a Taco with the top side filter so what I do it shove 2 rags on the bottom and change the filter with very little mess
anndel
Hawaii, USA
yes once you make a wrong turn or lose tension with the ratchet it opns up. normally i just use it to break ut koose then use my hands to remove the filter.
Tim C
At the shop I work at I bent a piece of welding rod around the neck of a water bottle and cut and bent a hook that will let it hang from the radiator support. When changing the oil on those I slip the bottle over the drain ****** and hook it. I can then change the filter, brake clean the filter drain then empty the bottle for the next go round. We have several customers with these trucks.
Sent from my XT1254 using Tapatalk
kctyphoon
Jersey/Staten Island
This might be a good alternative - if you just start buying K&N oil filters, there is a 1" nut welded onto the bottom of the oil filter's case.. This way all you need is a 6 point socket.. Been using them for years, in part for that reason..
mjoekingz28
Mississippi
I used to aim for finger tight. That way A slight grunt would remove them at the next oil change.
But,
I did this with my new vehicle with an extended drain filter and the can was coated with oil a while later. The filters usually state 3/4-1 full turn and I did about a half. So, either I am getting weaker, but a full turn would take a tool for me to apply, but I can strong arm three quarters of a turn. And, of course, a filter tool will be required for removal since either the heat or oil swells the gasket and makes it alot tighter, at least that is probably the reason they are tighter upon removal than at installation.
