I am getting a wilton wood working vise with quick adjust to finish up the garage.
Internet pic
Does anyone know, does the metal have to be flush with the bench.. or as long as the wood cleats you install is flush with the bench?
Also its been too long since wood class, but seems like when you try to saw a piece of wood you could cut into the bench, if the bench was continuous and no open corner, or do you use a 4x4 to space out the piece?
I mostly do automotive stuff but do you find a WW vise useful? . the larger surface area and lower pressure is, well, good for wood obviously. For example I could use it to hold an oil jug to drain out the residual oil easily, or hold a little tool tray to make up the lost of space, which isn't much since it is undermounted. I am no woodworker but maybe I can work with chisels and coping saws easier after installing this. I know you can drill a couple of holes on the bench for stops/dogs for more serious use as well.
I already have large bench vises so everything is covered.
Internet pic
