rpearlberg
Installing a new light switch timer. My old switches used a ground wire, but the new timer doesn't have a place for a ground wire. What should I do with the ground wire in the box?
Stuff it back inside the box.![]()
Is that timer UL listed?
Does it require a neutral?
See the black wire that ties into the other black with the wirenut on them, thats your hot wire, the single black is your load (light/fan ext) swap your wires on your switchIt does, and I have it connected....I think.
I have a hot, load, and then I had this neutral connected inside that cap (just removed to see what else I should try).
Nothing is coming up on the screen for the timer switch....
It's possible I have the hot and load reversed....maybe.
Your single black wire going into the box is your load wire, tie it to the blue wire on your switch.
Or is it? I cant tell. Do you have a meter/voltage tester?
Which wire do the instructions say is line and which 1 is load?![]()
If it doesn't have a ground screw on it, there should be a metal ******** it so that any exposed metal surfaces like the screws for the plate (or if using a metal plate) will be automatically bonded to ground. If you have a metal box, the strap will thus be bonded to ground. If a plastic box, there should be a metal strap in it that also bonds the switch to ground.
If the timer has a ground screw, attach the ground wire. If not, tuck the wire into the rear of the box. If romex or BX, the incoming & outgoing ground wires should be connected together and also connected to the ground screw in the box.
AFAIK, a residential grade 120V 15A toggle/rocker switch normally doesn't have with a grounding screw and I have never seen one. Sometimes wiring devices like a timer or a 3 or 4-way switch will have them. Industrial, spec. or hospital grade switches have grounding screws though for reliability/safety reasons.
Can you post a pic of the timer and/or the make & model no.? Some timers require a neutral connection and depending on how your light and switch are wired, will not work.
It's the Honeywell RPLS740B
I just got one of them installed and it seems to work. However, I still can't get the one I posted a picture of connected correctly. I taped/capped the ground and shoved into the back of the box.
Hi,
I just looked at the picture and it looks like the neutrals are connected with a grounding type wire nut................Change out that wire nut to a standard wire nut
That timer needs it own power source to be powered up because it is a timer and not a switch...The neutral must be connected from the switch or there is no circuit
Just sayin'
Bob
Looks like a plain old tan wirenut to me,the ground wire nuts that you can feed the wire through are green.Hi,
Just sayin'
Bob
Looks like a plain old tan wirenut to me,the ground wire nuts that you can feed the wire through are green.![]()
If you look close at the picture, you can see a bare ground sneaking "behind" the neutral wires at this camera angle. It then reappears from behind the tan wire nut.
BTW, it is kind of pointless to tape and cap a bare ground. It could have been shoved into the back of the box just as it was!
