Gladiator Garage works universal brackets/clips
csmitty
Has anyone found any universal clips that fit on the gear wall? It seems husky and craftsman used to have something similar but I can't find it offered anymore. I found a guy on ebay offering modified brackets and a separate universal clip but $3-5 a piece is a bit steep and it would seem it should be something pretty common with different gap spacing. However I may not be searching McMaster for the right name.
http://www.ebay.com/itm/1-Grey-Glad...160699?hash=item4d2de05e3b:g:Yi8AAOSwrklU4rUB
I've got a few odds and ends I'd like to mount on the gear wall.
Nessal
Craftsman sells something similar to this. It is part of their "16 pcs" hook set. It's really only 8 pieces but they count that plastic backing and the hook itself as a separate piece.
C
csmitty
I did look at those yesterday and didn't think about just removing the hook part. Would still need a little modification to get it flat but probably not to bad. With some surprise points it would be worth a try.
PoorOwner
CA
If you can get the metal rail the is for the cabinet you can cut as many as you like.
However the fit is not very tight and might need a foam Tape to shim it so it sits snug
Jsf721
LI, NY
I have some of those and they are ok. Mounted the fire extinguisher to it in my garage. Wish I would extruded more.
