I have the big boy 2763, which is what I bought for use on my lug nuts - well actually lug bolts. I just tried my 2454 M12 fuel 3/8" impact on the lug bolts that I torqued less than a month ago to 80 ft-lbs.
No go. It wouldn't budge them.
I rechecked the tightness by hand just to make sure.
I tested my 2454 M12 Fuel 3/8 w/ XC battery on lugs I torqued to 95 ft-lbs a week ago and it took the lug bolt out in 2 mississippis. I took out 2 bolts with equal success.
You said you were using the XC batteries - can you do the same test with the non XC batteries?I was baffled by MikeF's results compared to mine so I performed a second test.
I've seen it stated over and over that the batteries only effect the run time and not the performance. I don't know for sure myself though.
Retested 2454 w/ 2.0 battery on a month old 95 ft-lb lug not used in previous tests, same result or maybe 1/2 sec longer, could of been variation in my mississippis lol. Re-torqued and same result. This was of course on speed 2 as speed 1 does not do 117 ft-lbs.
Try pulling a lug off in a week or two and I guarantee it will take longer or may not even be able to break it loose.
There is another part to the equation. The size of the socket makes a huge difference in the impacts ability to remove a bolt. They sell special honda crank bolt sockets that r 3x the weight of a normal one for this reason. The m12 fuel will have no problem removing a property torqued lug nut as long as you have a heavy deep impact socket. Rusted or corroded over torqued nuts are another story.
If you had to have the nut off in a hurry every time then step up to an m18 and don't worry. Other wise use the right socket and an m12.
extension will rob a lot of power.All my tests were performed using a deep 17mm impact socket with 6" extension.
That's encouraging - I just bought the 2454/M12 ratchet combo kit and I've been wondering if I should get the M18 3/8 compact fuel impact as well. I've got a IR W7150, but almost never use it, because of it's size. That 2454 is amazingly strong for it's size and weight.All my tests were performed using a deep 17mm impact socket with 6" extension.
Hi All - My first post here and I wanted to share a project I just completed on my Milwaukee tool chest. After lurking around here, lusting after some of the Snap-on boxes and researching the US General & Masterforce boxes, I settled on the Milwaukee. So far it works well for my needs. I wanted to add some task lighting and had some extra LED tape lights that would add minimal weight to the lid and allow a installation with no modification to the box. The tape lights are Armacost brand, both the 120 and 60 led per meter density. The latter was left over from a prior project. The transformer is concealed within the double-wall of the upper box and everything is switched from a magnetic switch you can see in the back right corner of the box. Hope you enjoy and feel free to ask any questions!
You need the 6 bay multi volt rapid charger. I noticed in the price check app at HD today it was on clearance for $100, not sure why it was on clearance, I already have it, would of bought another but it was not in stock.
Should be the case for 2797-22
Thanks I think I found one to order. About 22.00
Can anyone say if the 3/8" Fuel M12 Impact can reliably break lug nuts (torqued to 85ftlbs)? At 117ftlbs rated torque I'm skeptical. Not much better than my impact driver.
I want a 3/8" impact for mechanic and track (wheel change) use, but I'm not sure this is the one.
I don't see the advantage of that charger. I can charge five batteries at once. I only have M18.
Scored a new in box, missing one battery, M12 Fuel 3/8 impact today! $100!!!!
tool, one battery, charger, and hard case....couldnt pass that up!
Can you say Beast of a cordless tool?
Now to find the absolute strongest 3/8 adapters made.
Just remember you will have to mod it slightly to fit the hammer drill.
The Milwaukee Shockwave hex to 1/4, 3/8, 1/2 set is only $10 at HD. Dont know how they compare in strength to anything else, but they are impact duty.
Thanks. I'll pick some up tonight.
In my experience, a drill driver typically has less chuck runout than a hammer drill, so if Your using it on metal a lot it's been my experience non hammering drill drivers typically have a truer shank. Doesn't much matter on wood IMO.Question.... Besides the obvious, what is the difference between the Hammer Drill and the Drill Driver? I watched a review of the hammer drill and it has 3 settings, drill/screw/hammer. Why would a person ONLY buy the drill driver?
Thanks
CD
Thanks
CD
On another car, torqued to 95 ft-lbs a month ago, again in 2-3 mississippis each it removed 2 different lug bolts. Re-torqued them using 2 different torque wrenches to make sure my main one was accurate, took bolts out in same time. Torqued another bolt to 100 ft-lbs, out in 3 mississippis. My torque wrench only goes to 100 ft-lbs, tightened past that we'll say it was 110 ft-lbs and my 2454 removed that in 6 mississippis.
I think Mike's 2454 is defective, or his lugs are corroded/seized, or his torque wrench is inaccurate lol.
OK, I read all the comments about my weak tool before I went to bed last night.
So I went out and brought the tool in. It was in my garage, around the freezing point. I also brought in another 2.0 battery, as well as an XC one. I let them warm up, put them on chargers this morning before going to work.
So I just got back from some testing. Now they zip the lugs off with a delay of maybe .5 second. I tried deep and shallow sockets, XC, 2.0 freshly charged as well as the 2.0 that was on last night. It really didn't seem to make any difference.
So there's the lesson. These things have more torque at room temperature than the freezing point. It didn't seem to be hammering any harder, but obviously it was. I didn't drive that car today, and it's still around the freezing point.
I believe the 2.0 and above provide the same performance. The 1.5's are the ones that are the 'standard' performance or whatever you want to call it.
