looking for a new air compressor
jonsdoghouse
I have been looking at different air compressors,and found the 7.5 hp 80 gallon two stage ingersol rand with 24cfm @175 psi. which seem to be higher in cfm compared to some of the other brands with same tank size ,hp etc.
I feel like this is the one I want to purchase but wanted some other opinions or expertise on air compressors. The ingersol rand model# 2475N7.5 price is 1,985.00 on compressor world and 2,099.99 on air compressors direct free shipping. Thanks
logguy
I prefer Quincy over IR. I had a Quincy that was made in the 1950's and had a friend put new rings and valves, it's still running like a champ almost 60 years later!!! BTW, I rescued the pump out of someone's junk pile!! The Quincy will be the last compressor you will have to buy.
http://www.aircompressorsdirect.com/Quincy-271CS80VCB/p857.html
BTW, the IR you selected is a 3 phase.
jamesemery728
+1 on the Quincy. I have a QT-5 that is +12 years old, still looks and runs like new.
J
jonsdoghouse
BTW, the IR you selected is a 3 phase.[/QUOTE]
Actually the 2475N7.5 is a 1-phase . The 3-phase245N7.5-230 or
245N7.5-460.
But anyway I appreciate your advise and thoughts. I did look at the "Quincy's"
and guess I am looking at the extra money versus the cfm and the ingersol is advertised as a higher cfm . Not to say the ingersol would outlast the quincy but in a shop that used primarily for personal use I cant really see the extra money.
JDMopar
Asheville,NC
I just bought a Quincy 5 horse compressor. Check the CFM @ 90 psi and see how the I-R compares to a Quincy rated at the same HP. You won't be using 175 PSI for anything, so the CFM rating at that point just looks like a big number. Heck, I've got a buddy that works for I-R....and he told me to buy a Quincy! I flirted with the gal at Northern Tool, and got the price on the Quincy knocked down to below the I-R price:) Best of luck with whatever you purchase.:beer:
bmwpower
Damn, you dog. How'd you do that? In store?
jopickens
Grafton, WV
I'm happy with my Eaton thus far.
7.5hp motor, 10hp pump (turns ~600rpm), 120gal. tank, auto water drain etc.
Slow and quiet for such a large compressor.
~45cfm @ 90psi
Josh
J
jonsdoghouse
Well Ijust ordered an eaton 7.5 hp. 3cyl. 80 gallon vertical. After hours of research and looking I decided this was the best compressor for my use.
I appreciate all advise and thoughts on this subject.
benjamming
Alabama
Gardner Denver has a division called Champion that would be worth researching. I have the Advantage series 7.5 HP 80-gal tank unit which includes the mag starter, air cooled aftercooler, pneumatic drain valve, & vibration isolators.
G-force
Oregon
Quincy FTW. We have over $50k in Quincy compressors powering the production floor where I work and they are great, plus the factory support is unbelievable.
bmwguru
I have an Eaton 7.5hp 80gal with the 10hp 4 cylinder pump. Very low RPM and quiet. I have been very happy with it so far. I've only had it since the first of this year. I did a ton of research as well before deciding on Eaton. Nobody could match the performance, added features and best of all the 5 year full warranty. I think you will be happy with your new compressor.
Todd.Brock
Cincinnati
I was at a small parts place today and they had Bel Air compressors. 80gallon single stage 23cfm.. Then I saw that Eaton is just down the road from me... Those are some serious compressors. Good thing delivery isnt an issue....Just back the truck up!
FFPL
Massachusetts
You will be happy. I have the same one and its a really nice (and very quiet) unit. And it's an excellent company to deal with.
riskyvt
Berlin, VT
johnsdoghouse-
You'll find the Eaton compressor to be of good quality & endurance. Awesome choice! Good luck.
jopickens
Grafton, WV
bmwguru - you are correct! I missed that one by a mile didn't I... That figure was the ~cfm with BOTH my electric compressors running...
I would like to get another 4cyl pump like we have on our Eatons and run it off my tractor PTO for when I'm using the big sandblaster. It has a minimum cfm rating of 50.
It 'works' with my two electric compressors @ a combined ~45cfm at the 90/100 psi range. But you have to take a short break every 10 minutes or so etc.
Josh
