dontlifttoshift
Which model is that?
2663-21 Includes one battery, one dual charger that will do the 12v and 18v batteries.
Is the m12 3/8" impact worth having if I already have the m18 fuel gen 2 3/8"?? Is it that much smaller??
Anyone with the gen 2 hammer drill - do you see any wobble in the chuck? Just bought the bare tool and Im seeing some wobble. I know my gen 1 didnt do it, but it took a couple to find one that were good.
Will the gen 1 chuck fit the gen 2 drill? If not, are there any other alternatives out there?
Thanks.
-Chris
Have you looked on home depots website? They have a deal where you buy the 3/8" impact kit for 200 and get the ratchet for free. They have one for the 1/4" ratchet and one for the 3/8" ratchet.
Thanks, I have and I already have a dewalt cordless impact so I am not really needing one. If I was I would definitely jump on this.
Ryan
It's thinner and shorter. But the head is longer. All depends on how the space your trying to fit in to is shaped. I have both and like/use them both.
I have both. I seem to always go for the M12 stuff unless I'm expecting to need the power from the M18 tool. My M12 fuel tools are my favorite power tools right now. Power approaching NiCad 18V tools without much weight.
I use the M12 3/8 a lot pulling things off the top of an engine.
Most the reviews online for the 2704 hammer drill I've read mention chuck wobble. I really wanted to get a gen 2 but this seems to be a very common problem with them.Anyone with the gen 2 hammer drill - do you see any wobble in the chuck? Just bought the bare tool and Im seeing some wobble. I know my gen 1 didnt do it, but it took a couple to find one that were good.
Thanks.
-Chris
Does the chuck look wobbly or is that with a true bit in it and the bit's wobbly? Most of the Gen 2 hammer drills I have and sold had a wobbly looking chuck but the bit spun straight. I had one person say theirs wasn't true and try to get a partial refund but when I told him he could return it he never messaged me again, thinking he just wanted easy money.
Sent from my SM-N900V using Tapatalk
Put a drill bit in it and pull the trigger. See if the drill bit wobbles. Ideally, you'd clamp down the drill and measure the runout.
Tried that, definitely looks like its wobbling at least a little at the end of the bit.
Tried the same with my 2604 and there is a little wobble but much less
Now not sure what to do with the 2704....just bought it at HD last week so I suppose I could ask for an exchange and see if I can find a better one.
Or do I try to see if the chuck is the issue, then just get a better chuck (there is a Rohm that should fit)
Will give that a shot and report back. Hopefully easy to do, since I got it discounted with the 150 off promoExchange it and see what you get. Make sure to try multiple bits to make sure it's not the bit.
Anyone have issues with the tripod light in the cold weather? Used mine two nights in a row on emergency calls at work, and the mast does not like to fully collapse when it's been out in the cold.. Feels like there's some air trapped inside, and I have to wait for the fixture to warm up so I can get the last 2 inches of the mast down..
Otherwise, the thing is friggin amazing.. Makes a huge difference for someone like me at work.
I guess anything is possible.. Feels like trying to push down a pneumatic piston.. Both stages were a little unwilling to slide freely..
I have both. And I would say yes.
No. The change due to temp would be out near 6 decimal places, nothing you could even notice, and they would change pretty similarly. As was said earlier, possibly condensation causing it to lock up.Any chance the metal tubes are shrinking due to cold, causing a very tight fit?
I ended up adding the 2704 to the lineup. Runout measured with a Mitutoyo dial test indicator, strapped down, is around 0.015. There is some visual wobble on longer bits. I'm unsure if I'm going to swap it out or just keep it. It's a hand drill after all not a milling machine.
Both. The best I can anyway.Are you looking at the knurling of the chuck or a fresh new bit in the chuck wobbling?
Mine has the grip pattern makes it look like it is wobbling but I have zero issues drilling holes in wood metal or plastic. The bit stays center on whatever mark I have made.
The sleeve definitely wobbles but it looks like the end of a bit (drill rod, actually) wobbles in the same "pattern" with the chuck sleeve. It's not horrible even on a 5" long rod, it's just that it's there so I wasn't sure if I should settle for it.
Sent from my Nexus 6P using Tapatalk
My rule of thumb is that if you are in search for drilling with precision you are wanting a drill press.
Just drilling hole be it in wood metal or plastic, cordless.
Cant decide between the 3/8 or 1/2 m18 fuel impact. They have essentually the same torque. Whose got some insight?
Fuel or non-Fuel?
Also depends on what you are doing.
Some new items - got the latest Milwaukee pliers except the iron workers version. For my purpose I see no need to have those and the lineman pliers.. Also replacing all my cheap Kobalt pliers in my rolling "driveway" box with Channellock stuff.. I guess I just needed something else to buy..
Same torque?Cant decide between the 3/8 or 1/2 m18 fuel impact. They have essentually the same torque. Whose got some insight?
Same torque?
The 1/2" 2763 impact has 700lb/ft fastening and 1100 breaking
The 3/8 2754 impact wrench has 210lb/ft
I have both and use the 3/8 primarily for auto work. Use the 1/2 on lugs, axles.
Really depends on what you're using it for.
