Yeah, you want a nice long pipe handle in the hole on top!
have had this old slow speed high torque drill for a while.
Mor-Power distributed by Canadian Tire
got it a few years ago , tonight decided to;
disassemble, clean, media blast, wire wheel, regrease, assemble and put back on the shelf to last another lifetime.
some grease was very dirty, yet some seemed to never been run though the gears.
looking good as new
** removed pictures to save space **
Love that drill.. I remember using similar drills to stir barrels of paint when I worked summers at the painting contractor my father worked for..
Nice restore..
Here a couple of pics...![]()
That drill looks like a real arm twister, at least my arm has been twisted a few times with similar drills. Nice job.
Beat me to it. That was my first thought when I saw it. But, what a beautiful tool.
well as the plug shows, this is NOW just used for mixing paints, mud, grout, etc... so nothing that should cause any arm twisting.
the one time I did use it to "try" and bore through some wood it didn't have enough speed to "cut" into the wood so it just bit in and quickly twisted out of my hands.
very happy with how it turned out, may have to do the same for an old SkilSaw WormDrive I have kicking around too.
Cleaned my garage on Sunday! Getting closer to being able to park on my side again. One more task of putting stuff away and I should be good.
Regards,
Jeff
Sent from my bag phone...
Curious what media did you use to blast it ? I have several old craftsman / simpson alum cased tools and want to clean them up some but not really wanting to do so by hand.
Cypher
How do you like the Harry's razor setup? I have been thinking about trying it out. Having to be clean shaven for work, and buying new high priced gillete blades doesn't impress me.
The ultimate in penny pinching is an old DE razor. My wife got me this one several years ago, & now I despise using typical, modern razors. I bought 50 Feather blades for it not long ago for less than $15. A blade usually lasts me about a month.
I realize it's not for everybody. It has a learning curve that many aren't willing to suffer through. I bought one for my dad & he said he almost took his face off.
That's beautiful.Started the motor in a 64 Mustang that has been sitting for 4 years.
I'm very pleased with Harry's as an alternative to every other disposable type razor out there. I have tried everything. My facial hair is brutal on razors, it's like piano wire. The Harry's razors (I have two) are both a good value and a quality product. What's more, they have good customer service. What about the shave? The shave is very nice, almost as good as a safety razor, but requires less attentiveness and prep work so I use it as my 'lazy razor'. The blade life seems to be much better than drug store options, but how much better, I'm not sure because I haven't kept track of it very well. Also, the shave gel is the best I've ever tried. Very nice product.yes, seen those, just curious about "Harry's" experience.
Not worried about learning curve, as I have thought about them... just looking at other options.
thanks
I actually used to cut myself more with the quadruple million blade techno aerospace GT razers from Gillette and the like. Once I switched to a safety razor I think I've done it maybe once or twice. I got my girlfriend switched over to a safety razer for her legs too since she didn't like the crazy stuff they sell for women much either.
Best way to describe it is think about it as always being a front wheel drive car. It always pulls from the handle and the back end just follows. Avoid oversteer. You'll cut yourself if the head moves sideways but as long as you always just pull from the end of the handle and don't press in but let the weight of the razer do the job you will get a nice shave with no blood.
Put a hinged front on the garage workbench that I moved up from the basemet workshop. The prior workbench had a place to display old wrenches and I needed to make this front to do the same plus make it so that I can get to the items stored on the under bench shelf.. Got it all complete except for the mess cleanup ..
View media item 57856
View media item 57857
I took a bunch, but didn't post them... want to see the rest?
Steevo: Very nice Chess set your making. What is the distressing process /method you have applied to the brass casings of your Chess set?
For the shiny ones, I started by using a tiny torch (Smith little torch) to melt/burn details over the surface, then cooked them in some jewelers "pickle" solution to clean them, then buffed them with green compound and a soft wheel, followed by a light coat of "Reniassance" preservation wax.
For the dark ones, the same torch process, followed by a shorter pickle bath (brings out some of the copper color in the brass, then fuming with hot ammonia fumes (closed container, that stuff will kill you) to darken them, then a soft buff and waxing.
Is the details/design purely random or something specific? I really like it .
