I've got a 1939 Snap-on "Red Cap" top and bottom box combo that I'm going to be restoring.
It's in rough shape... as the hinges failed in the past, the previous owner whipped out the brazing equipment and had at it. As a result, I'll be replacing one of the heat-warped doors on the roll-away, and will be getting new piano hinges from McMaster-Carr.
I'll have it soda blasted down to bare metal, do the welding repairs, fab the door, fix and replace the slides with some donors I picked up a few years ago, and then repaint it.
Anyone have suggestions for the paint? I won't be priming/sanding the paint, just painting it like they originally did.
Should I order the paint from Snap-on, have it color-matched at a paint shop, or is Hard-Hat Rustoleum spray can red good enough? I've had great success with that paint on a lot of projects in the past.
Anyone know if Snap-on has changed the shade of red over the years? That would be the big question as far as getting the paint from Snap-on.
-Brad
-Brad
Good luck with yours.
sorry man.
