Vent Baffles for 48 inch on center?
493 scamp
Kirkwood,Illinois
I have trusses at 48 inch on center and am looking for baffles to use between them to vent and also to keep blown in insulation from going into walls. What did you guys use?
4cyclic
Grand Isle, Vt
I used 1/4 inch osb 4x8ft cut in half, so it makes 2 baffles of 4x4. Did the job with 2 1/2 inch air space channel.
Dragfluid
Pillager, MN
Same here, except I cut mine length ways because my trusses are on 8' centers. Simple, cheap, effective.
I think there's a pic in my build thread.
bullnerd
Jersey
I used the 24" ones from HD. I taped the center of them together with some leftover tyvek tape and installed them as one piece. Stapled up, was quick, cheap and easy.
Should be able to see them in my build, link in my sig.
Highbeam
Mt Rainier foothills, WA
I had 12' spacing between trusses so instead of screwing with baffles I just laid two rows (4 feet) of batt insulation next to that soffit and then blew in up-to the batts. It actually worked really well and no blow in made it past the first row of batts. I put in R-50 of cellulose and the tallest batts that would fit while maintaining an air space along the edge. They were like R30.
