Oxidized Aluminum...Cleaning
Bolster
Mexifornia
What do you recommend for cleaning oxidized aluminum, as can be seen in the Proto flexible file below? Buffing, of course, but that won't do much for the recessed areas...
Vicegrip
NoVA.
Gentle glass bead blast. Set down to 30 psi and hold the gun back some. Just enough to knock the crust off but not change the metal.
The Rusty Gear
Edmonton, Canada
Ask an anodizer what they use to clean the Al before anodizing it (I can't remember off hand what the acid is)
Are you planning on protecting the aluminium after cleaning it? Aluminium oxidizes fairly quickly.
fatfillup
Finksburg, Md
A solution of Oxalic acid will work great. Oxalic acid reacts only with oxidized material so you can clean of the oxidation without going after the good metal. It is pretty safe to work with also.
Now, where do you buy it? I have a polished aluminum maintainer that contains oxalic that we sell and many deck neutralizers contain oxalic acid, so you can try a local pressure washer distributor or a paint store that sells deck sealant and thay may have a product.
A dilute solution 5% or so will work better than a stronger ratio.
Its not fast, an hour soak or better, but it will work.
-B-
Northshore of Boston
a bath of strong Tang then use a brass brush to clean up the small stuff. Keep an sharp eye on the bath and when done rinse with water do not polish the tool they never were polished when tou get the finish you like hit it with some spray wax and you are done.
The Rusty Gear
Edmonton, Canada
I thought Oxalic acid is what was used to anodize (ie oxidize) the aluminium!
Bolster
Mexifornia
Tang?? The orange drink?
Krusty: NOT FUNNY! (OK, very funny! :lol_hitti)
Bolster
Mexifornia
Notice the difference between the two...they are probably close to the same age but look how much worse the Proto weathered the years than the Heller. Perhaps the Heller was protected somehow? I dunno, a spray coat of lacquer perhaps?
The Rusty Gear
Edmonton, Canada
Could be different Aluminium alloys too. Laquer works for a while - cheaper than but not as good as some form of anodizing.
fatfillup
Finksburg, Md
Don't know about the anodization process for sure, but i believe its a coating that is added. Oxalic acid may be used in the process but I don't believe it imparts the coating. Also, on the lable of the product i sell, it states, do not use on anodized alum as it will affect the surface(remove the coating)
What i am sure about is oxalic is definitely used as a polished aluminum maintainer (think mirror finish on tractor trailer wheels and tanks). While it will not impart the shine, as that mirror finish degrades, it is oxidizing and the oxalic acid will remove the oxidized material and leave the good shiney aluminum alone.
I have also used it in dilute solution to remove rust from tools as a cheaper alternative to EOR. I've also had customers use it to clean old motorcyle motors with good results.
Elroy
kentucky
Now, where do you buy it? I have a polished aluminum maintainer that contains oxalic that we sell and many deck neutralizers contain oxalic acid.
This is what Elroy recommends:
The main active ingredient being Oxalic acid. Try it. you'll like it.
Ramblur
Central FLA
www.rustaid.com should be available at your local hardware.
I used this on the coolant passages of an aluminum head for a Hudson
Hornet engine and it ended up looking like a new casting... oxalic acid
Vicegrip
NoVA.
You clean with lye before anodizing. It eats right through and removes the ****. IMO t does not leave a surface you want to use. Cans of good old school Drano is an easy way to get lye.
fatfillup
Finksburg, Md
I checked the msds and it also contains hydroflouric acid. BE VERY CAREFUL!!! Hydroflouric acid is amoung the most dangerous to be around. It absorbs through the skin and attacks calcium (bones). Get it under your fingernails and you want to cut off your finger the pain is so bad for 2 days.
That said, the product probably does not have much in it, but be careful anyway.
Bolster
Mexifornia
Ole Elroy had the solution. Found some Barkeep's Girlfriend in a grocery store and I got just the cleaning I was looking for...original condition, but clean.
Thanks Elroy! :beer:
Bolster
Mexifornia
Bolster, a little more detail on how you cleaned the tool. Looks great.
Well sir, a stiff bristle brush, a little sprinkle of Elroy's "Barkeeper's Girlfriend," a few drops of warm water until it becomes a paste, and apply elbow grease with the bristle brush. And leave the paste in contact with the aluminum a minute or two.
Try it, you will like it! It's not an "aggressive clean," it goes slow enough you can stop when it's where you want it. I didn't want it to look "new," just clean and not corroded.
Major Ramifications
River Ridge, Louisiana
A bath with some strong tang will remove corrosion? Are we taliking about the **** flavor?
