The VISES of Garage Journal
Is anyone aware of how to date a Yost vise? i got that 104 1/2 all apart.. wire wheeled it and its all sitting in simple green rite now.. though only about half the slide fit into the 5 gallon bucket.. so ill have to dunk that again upside down to get the other half... anyways.. on the main nut there is a triangle and a number 4.. just wondering if that had anything to do with year?
It's certain to be over 18, so no worries there
The usual advice for dating a vise is Flowers, Dinner and a movie, and see how far that gets you...
:evil:
Joe, How many beers does it take to polish up a vise like that ? Nice job
I finish a small 1 3/8" vise. This is the first one I have seen with the screw and slide side by side. Check out the offset jaws and little anvil with a horn on it. The center mount brass washer and handle look cool also.
Get, that is VERY cool! Any clue on the make?
Shiftless
East Bay SFO
I wont be using this vise. just gonna clean it up, paint it and put it with the few others ive "restored" . Would you still recommend the drilling? or just leave it?
If you just keep it on a shelf, I wouldn't drill it.
As always, others are welcome to chime in with their advice on this subject.
arch stanton
Just finished this Parker 973. Painted in Hammerite red (which is more crimson/cranberry). Jaws came out good except when I sneezed and took just a smidge more than i wanted...oh well.:eek:
I ground and polished the handle and painted the inset section same as the vise. Also polished out the 'anvil'.
This is a 1950s model from Parker so the jaws are like new. Remade the handle and cleaned up tensioner.
Im not crazy about this red but im just sick of black and blue. Its going on eBay so we will see what the market thinks.
Darn nice looking vise
Bogash
Shenandoah Valley, Virginia
Just bought my first old vise! Wards Deluxe Quality on it. Pretty cool for 10 bucks! I know it's not a Wilton or super valuable but I like it! Hopefully it cleans up okay. Going to try electrolysis for the first time. :)
Hemi49
Rush (Rochester), NY
Joe
Great job......FWIW, I like the color....
Hemi
Bog, for an exposed screw, that is a pretty cool looking vise! for that one even I'd have given $10! (and I'm usually topped out around $5-$6 for those!)
Looking forward to what you do to it!
honza.vosalik
Missouri
Beautiful! Could you go in more detail regarding how you polished those parts? Thanks!
bagged89s10
CT
You did good joe! :thumbup:
joe.striper
agawam, ma
Everyone does it a little differently. Veeps, who responded below your post, is the best at it. You have to try different methods to get it just how you like it. I go from a bench sander to some 3m wheels to buffers. I am always experimenting. It can be a lot of work and then you have to work hard to try and keep sharp edges etc....but if it comes out well it really looks nice.
I'm trying to repair a surface grinder just to do vise anvils. I have a hell of a time getting them perfect and it drives me crazy.
Thanks for the compliment.
honza.vosalik
Missouri
Did you also clear coat the polished pieces?
CrotalusAtrox
The Great Southwest
Found a really nice Dayton bench grider also worked on the Athol 614 today had to use the angle grinder to get the static tower cleaned up lots of gouges. Tomoorow the sanding begins
joe.striper
agawam, ma
Just finished this 3.5" Wilton bullet. All original. Had 4 coats of paint, gray, white, gold and original. Took 2 weeks in Simple Green to geit all off. Painted it twice 'cause i **** at painting. Looks OK, not as nicevas the Parker.
Z3K3Y
Canada
looks great!! i bought some simple green for the first time the other day. i got it mixed about 3 gallons of water to 1 gallon. I have a yost that has been in the solution for about 6 hours now. has anyone ever tried running fish tank air bubblers in the simple green? i was thinking the bubbles would help take the grime out just like regular soap.
jakemac
New England
Never tried diluting SG, I always use it straight up.
I'm wondering if an air bubbler would cause the SG to foam up. :dunno:
Shiftless
East Bay SFO
Does soaking in undiluted SG remove paint? Old rattle can paint? Ancient factory applied paint?
Agitating the liquid would certainly help break loose crud. Wouldn't it be great to have an ultrasonic cleaning bath big enough for our project vises?
jakemac
New England
The only coating soaking in undiluted Simple Green hasn't removed for me yet is the primer coat on a pair of Dake 00 presses. If you soak long enough, SG will even remove the chrome off of an old pair of vise grips (forgot 2 pair in the bucket for a couple months). It even removed the filler coat on a Reed vise, I'll have to re-fill the voids to smooth out the casting before I paint.
Filtering your fluids after use will help them stay viable for years, with only refreshing with new as evaporation and spillage lowers the level. This helps to mitigate the cost over time. Simple Green, EvapoRust, and CLR all get filtered in my shop.
FMC1959
Montreal, Canada / Upstate NY
What do you use to filter the SG, something like paper coffee filters?
jakemac
New England
I buy coffee filters in bulk to lower the cost. Its a slow process to filter a large amount, so I tend to degrease/depaint in batches before filtering. I suppose you could set something up with bulk cheesecloth, air filters, or something similar. The important thing is to remove particulates at the smallest level possible so that they aren't degrading the solution while in storage. I typically filter multiple times before storing back in the original containers.
When done, I dry out the filters before throwing in the trash, to avoid combustion risks.
(I do the same with all my rags)
Z3K3Y
Canada
i was thinking of adding a spigot to the bottom of my SG bucket.. so i can put another bucket underneath it with a filter on top.. then just open the spigot enough for it to trickle out .. and let it trickle out for an hour or so through the filter into the empty bucket. Discovery should of done a Mythbusters episode on restoring vises!
Bogash
Speaking of Evaporust, O'Reilly's seems to be the best place to buy it. I got a gallon this weekend with military discount for under 21 bucks. Harbor Freight is at still $22.32 with the 20% off coupon. I won't have to buy again for 2-3 years since I filter is back like you guys but that's a good deal. :thumbup:
Z3K3Y
Canada
Evapo Rust is discontinued at Canadian Tire in my area.. is there any alternatives or similar products?
bubinga
beautiful:p
FMC1959
This^^^ Diluting it will slow the process. toy do want to be careful with Aluminum parts however long soaks can damage the aluminum.
I've used it for House paint, rattle can paint, almost every kind. Only 2X has the paint sneered at the SG. Once for whatever is on my Canedy-Otto DP (Epoxy paint? :dunno: ) and again over the weekend on some paint on a hammer handle. :headscrat
For agitation I would use some sort of small recirculation pump, but I'm unsure what SG might to to plastic over time...
Coffee or paint filters should do fine. I just let the paint settle on my House paint brush soak jar and pour the top SG off into another jar, then let the settled paint dry and toss... I'll have to give filtering a shot as well.
I'd have the spigot an inch or so high as the SD bucket will also be a settling tank. You want the good stuff, not the sludge.
ChargerRT
Louisville, KY
First off... whew... went through page 1 through 4 twice before I found the vise post... Scared to death it was deleted.
Alright fellers... what do we have here what do we have here.
Seller claims its probably a 4 1/2 to 5" jaws... no repairs but I can't tell exactly what make or model it is.
exmaxima1
Midwest
Whatever it is, it's worth the $40 the seller is asking.
drivesitfar
Charger: it looks like a nice old vise and could be one of several quality old US made vises. the writing fades out too much when blowing it up, but doesn't look like a Rock Island even though the vise does. it might be an Athol, but it has the wavy cast lines on top of the jaws like a Rock Island so maybe a Sawyer. the only odd thing I see is the swivel pin might need a new nut so I might see if it works and maybe take it apart. even just putting a regular nut back on it might work as well as that double nut.
just check for cracks on the back of the dynamic slide and if you want unscrew out the dynamic all the way to check the vise nut and screw if you want to and have time.
the bench might be worth owning too if you need a good old solid wood bench.
bagged89s10
CT
Yost is my guess. Reeds, athols, and rock islands have the writing oN the opposite side.
scooternut
Pittsburgh, PA
Columbian 505 in BLO finish
Had this one for awhile and finally got around to reassembling in. It was really messy looking and all bound up when i picked it up. Cleaned up real nice.
CRSINMICH
Southeastern Michigan
