Want more tech info than what I previously posted (here in this thread and also in another recent thread, and several other times here on GJ IIRC, as well as 'other' places)?
The thinner/solvent for water-based acrylic/latex paint is water.
Flood Company's Floetrol product is a flow-control product for use with acrylic/latex water based paints. It actually slows down the drying time and gives the paint film a bit more time to try and flow out and self-level.
Although (various) 'common' alcohols (isopropyl, ethyl, methyl, etc) are (usually) liquids at room temperature, they typically have an evaporation rate
higher than the water that is in the liquid acrylic/latex paint. Thus they will evaporate rather quickly when you spray that witch's brew of paint+alcohol. The alcohol also chemically 'screws up', to varying degrees, the "resin" (binder) in the acrylic paint (temporarily and/or permanently). Most acrylic paints are
not alcohol resistant, alcohols will usually dissolve (to varying degrees) a dried acrylic/latex paint film.
So why in the world do you want to add a fast evaporating liquid that will interfere with the paint forming a durable dry paint film (at least temporarily, and possible permanently) to the paint?
How about this info
http://homesteadfinishingproducts.com/wp-content/uploads/2014/04/paintspraying_ver3.pdf
How about here
http://www.sherwin-williams.com/hom...-and-staining-faqs/painting-application-faqs/
Look for the FAQ about thinning paint, which says:
Q: What adverse effects does thinning a paint product produce?
A: Most products are ready to go right out of the can with no reduction necessary. Some products can be reduced to some degree. The product’s data page will indicate the maximum reduction allowed if any and the correct type of reducer. Please note that reducing a paint product past the recommended levels would produce a solution that may not offer the same performance characteristics as those indicated on the product’s data page. Always use the recommended solvent and never reduce past the amounts recommended by the product’s manufacturer
Another snippet from S-W regarding alcohol and paint:
How do you know that a wall was previously painted using oil-based paint? Is there a way to tell if the paint that has been applied to a wall is oil, semi-gloss or flat? Most of them look the same after years of use.
Pour a small amount of alcohol on a rag and rub the surface. If the alcohol just cleans the surface, that indicates it could be an alkyd coating. If the alcohol gums up the surface rather quickly or removes the paint film immediately, that possibly indicates a latex coating.
Want to call Sherwin-Williams yourself?
Ask Sherwin-Williams
Give us a call and get quick answers and information.
Mon-Fri 8:30am-8pm EST
Sat & Sun 9:30am-5:30pm EST
1-800-474-3794
