I am back with two more questions that hopefully have simple answers but doing research online I don't seem to come up with a definitive answers.
1. Does code require an exterior electrical receptacle on a detached garage? I did not plan to have one but can't see anywhere that it is required.
2. I saw this quote online today...."If you were to run a neutral to one silver/white screw on the receptacle, then continue with another wire from the other silver/white screw onward to the next receptacle, you could not remove the receptacle and keep the neutral uninterrupted, a violation of the code[. Because of this, you will need to use individual GFCI receptacles at each box."
I wired my receptacles with incoming neutral on one silver screw and outgoing neutral to the other silver screw. I only have one GFCI at the beginning of each receptacle circuit then standard 15 amp TR receptacle after the GFCI. Is this O.K. or would this wiring method require a GFCI for every receptacle? In other words, if you use just one GFCI in the receptacle circuit do you have to wire nut the incoming and outgoing neutral with a single pigtail to one of the silver screws? The above quote really confuses me.
This took down my computer, cable modem, router, etc.
