let's see your craftsman block grinders
Pupuhd
New Jersey
PUP: nice work on the badges that is for certain. also the 1/3 block you restored is high up on the list of GRINDER **** and maybe the nicest 1/3 HP we've seen. BETTER THAN NEW in my opinion.
WELL DONE
Thank you. I still need to post(thread) that rebuild,not many photos or details on it, but hopefully helpful to some one. For the next rebuild of the 397.19410 ON/OFF/BRAKE model, I'll have more photos and plenty of details with it.
David
drivesitfar
PUP: if you do a thread or even post it here on the best way to remove and replace rivets and the tools you use. like I said the labels look amazing and I bet if you teach us how to remove and replace them there will be a lot more good looking blocks showing up.
thanks again for doing all the work you've been doing.
G20-Budo
Chandler, AZ
Okay. Here is is. Cleaned up really nice! Rustoleum Hammered Black for stand and Rustoleum Satin Nickel for center tin. Nothing for body, it shined up nicely. I have $68.01 in it plus my time. :D
Bogash, that looks GREAT! You did a nice job on it, and the price was right!
Pupuhd
New Jersey
CRAFTSMAN BLOCK GRINDER BADGE REPRODUCTION
Tonight I just took delivery of two badge models, both the 397.19580 non-INDUSTRIAL RATED and 397.19670 GOLD background. Both will be worked on by this weekend and ready for shipping to those that ordered to date. The gold version looks gold in color as in the previous image posted, not metallic, however with a glossy finish. While the non-INDUS. RATED is the same as the previous order in Sheer Matte with the brush aluminum coming through the blank areas. Enjoy and thanks-David
Pupuhd
New Jersey
Thanks drivesitfar. The information is also on post #37 in my thread Machine Name Plate Tag Reproduction (http://www.garagejournal.com/forum/showthread.php?t=323165) and also in my signature, however I'll post here also.
First, as far as removing the original rivets in the center band I simply used a grinding wheel to grind the upset on the back of the rivet. You can use any size grinding wheel from a dremel version to a larger 4-1/2" wheel. Also a grinding stone or Tungsten Carbide Bur Cutting Tool installed on a dremel or 1/4" air die grinder will probably be better control behind the tight confines of the center band. The original rivets are know as either Semi Tubular or Tubular Rivets, a special tool or machine is needed to pinched the hollow or tubular end over onto the back of the center band.
When I first got the inclination to use actual solid rivets I didn't do my homework too well as far as availability online. The ones used I purchased on ebay for about $4 for 50. They are aluminum domed solid rivets shaft is 1/8" diameter by 1/4" length, head is .25" diameter by .10" height.
However McMasterCarr has a far better selection, mostly $5 for 250. The one similar to above the head height is .064", slightly smaller profile. These I will get next when my current stock runs out.
At that point I did some research and found out that you can use a cheapo Harbor Freight Medium Barrel Air Impact Hammer for under $10 on sale as a rivet gun.
Then I purchased on ebay a Rivet Set AN430 1/8" Round Head($10) to fit a straight .401 shank rivet gun.
Basically those air impact hammers have a .401" diameter female shaft opening the same as those high end expensive rivet guns. Same gun, one is modified to pound rivets all day while mine, well "it does the job" for me for under $25 total cost. Thing to note is the Rivet Set tip has to match the rivet head profile you intend to use. The concave profile on the tip will fit over the 1/4" diameter dome head on the rivets I have. To keep it on the inexpensive side I used a piece of 1/2" thick steel bar stock as a Bucking Bar.
Here's my setup, you'll noticed my Bucking Bar in the vise. Also, it's recommended to use about 40psi pressure. Rest the rivet shaft end up against the Bucking bar and raise the center band up against the back of the rivet head while holding down the rivet with the Rivet Tool tip. Three to four quick burst of the trigger will set these aluminum rivets in a couple of seconds. As soon as you pull the trigger let go, this will give about +-6 blows to the rivet head. Just remember it's an aluminum rivet, not steel ones installed on the Titanic. After each trigger pull check your progress. Also make sure the Rivet gun is perpendicular to the rivet, otherwise you will get a Smiley cause by the edge of the Rivet Set tip.
TIP: Take a small machine screw and nut and install it diagonally opposite your first rivet to install. This will keep your badge in perfect hole alignment when pounding with the Rivet gun. Once satisfied, install the other two then the last one where the screw and nut were. I made this mistake and used another rivet for alignment and it bounced off while working on the first one. Had the first one done and solid however the other holes fell out of alignment enough that the rivets would not go in the holes, had to drill/file them for proper fitment.
Btw, I'm in no way setting these according to aircraft specs, I believe the rivet shaft end when compressed is called the Upset: diameter of the Upset should be 1.5 times the diameter of the rivet shaft and the Upset thickness .5 times the diameter of the rivet shaft. Heck I just want the badge to stay put.
Back side showing the Upset of the rivets. Also the same procedure done for the brass etched Rebuild Badge I created.
Btw, since then I have also purchased Flat Head Solid Rivets in the same dimensions as the dome head ones.
I will make these available as a choice to ordered CM badges. For my AH Manual Motor Stater switch tag I want to use the flat one for the install, every others I will stick with the dome heads. Also for those that may not be able to set the dome ones with the air hammer setup, these flat ones can be peened on the back with a small ball peen hammer. Just take note that the flat surface you put the head on to act as your Bucking Tool must be smooth, otherwise any imperfections on the surface will transfer to the head when peening the shaft end. Also with this setup you will have to take great care to protect the new badge not to scratch or damage it since it will also be up against your Bucking surface <---only draw back, you've been warned. My recommendation, choose the dome head solid rivets, I believe this will be a safer install.
Hope this helps - David
G20-Budo
Chandler, AZ
PUP,
I'd like to double what Drives said.. GREAT work on the badges AND the rivet info!! I was wondering how I'd put the rivets on and make it look "correct". :thumbup:
Bob Hall
Parkersburg WV
Don't know whats harder, finding a nice CM block grinder, or posting from my phone! Anywho, I did finally get one. not far from the house, and in nice(not perfect) condition. The original water pan is there as well as both "shatterproof glass" shields, and a part of a CM drill grinding guide. I'll paint the base and replace the wheels. and I'll be contacting the GJ member who makes the replacement tags. It looks like the original paint will clean up pretty good, so hopefully that's all it will get.
Thanks for looking......
CalsXS2
Very nice find. I really like that light too. I found one a lot like it that was missing the shade. So I made my own and put it on my drill press,,,lol.
bluebolt
Benton LA
Picked up this 1/2 HP Block with Craftsman pedestal stand today, runs smooth, light works, water tray and all original feet are there. Needs one eye shield.
erty67
Very nice. I like the table saw too.
04chase
SO CAL
can we get back to who is selling me a 1hp 8" grinder ? seller please pm me if you dont want to get bombarded!!
BTW im serious to you who have one .
McBrownie
Cleveland, OH
Really nice find. That Vimco lamp is worth $50 by itself. Hard to tell from your label, but looks like a 1/2hp Commercial 397.19590. :thumbup:
Bob Hall
Parkersburg WV
Thanks, that's good to hear. Here's a little better pic. The tag seemed to have taken the most of the wear and tear from use, not sure what the PO was grinding.
mbsinmich
Ha! Your label looks like mine does!! Have you seen the new badges that pupuhd makes? He just ran a batch of your particular label. See post #8368 for more details.
torqueman2002
SE Michigan
Here's a very short list of Block grinders and the bearings I've kept records of, when I replaced them.
I've placed an XL file on/in DropBox for anyone to update with their bearing information.
It's a save-only file, so just give it a unique name and sent it to me by eMail, post your info here, PM me, ....
I will maintain the file and post updates here and on the ".... What's the Fuss?" thread in my signature line.
Comments, suggestions are welcome. :)
https://www.dropbox.com/s/g0kb1804ddbm9bq/Block Grinder Bearing Details 16-04-03 a.xlsx?dl=0
torqueman2002
SE Michigan
I received a box in the mail yesterday.
Inside was a freshly 'minted' set of CM Block grinder 2-piece tool rests.
They are a thicker 'gauge' metal than OEM, as can be see from the RH tool rest from my 3/4-HP m-397.19350 'Maroon' Block included for comparison. Note: The 'silvery' color is a result of media blasting.
The fastener threads into the tapped holes easily.
Well done, sir!
:thumbup:
PCMusicGuy
Houston, TX
I blame you guys. Came home with this for $30. Works great.
Mac339th
Northwest Arkansas
Decided to bring it home... Much more clean than the photo showed on Craigslist. Had planned on doing a cosmetic resto, but other than cleaning off the dust, it's too clean to worry with.
S4cruiser
NC
That's a real nice deal for being so clean :rocker:
WWShop
MN
I saw a 1 hp in my area that looked in decent condition. We are away on vacation but I notified another GJ member but he said it was long gone when he got there to check it out. Oh well. Hope to find another 1 hp someday. Another ad in my area for a 1/2 and a 3/4 that are in good shape but the person wants $140 and $150. Too much for me.
Pupuhd
New Jersey
b7d3b627b317ad0ff92de39ab2c1724e.jpg47e5364286b6ccb4c2bc1bd656e308d1.jpgMust have been raining 1/3hp Block grinders this weekend. Sunday morning from Craigslist 1hr posting just 25 minutes from home. PO wouldn't budge from the asking $30. Couldn't resist, it's in great not abused shape, just missing rubber feet and spark shields.
Model 397.19580 non-INDUSTRIAL. Original bare bones model with the knockouts for the light and quench tray still intact.
Number three for me CM Block grinder out of six total now. Will probably use this ine for fine wire wheels.
Just happen to know a guy who knows a guy who's uncles garderner next door neighbor has a brand spacking reproduced matching badge.
I "see" said the blind man to the deaf man as he picked up his hammer and saw.
torqueman2002
SE Michigan
Yes!
Another, of the ever so numerous, 1/3-HP m-397.1958x Blocks in fine condition!
$30 is a v. good price for that one, BTW.
:thumbup:
Pupuhd
New Jersey
Update on the Craftsman badges: just arrived today, the 397.19410 ON/OFF/BRAKE badges. For three buyers who orders these, they'll be ready for shipment soon.
Also the generic blank Sears, Roebuck and Co. machinery badges will be available for sale soon.
