Job/Workplace pictures
nismomans13
Pittsburgh, PA
A few powerplants that I frequent
Keystone Generating Station in Apollo, PA
Hatfield Power plant, Masontown, PA
Art From De Leon
De Leon, Texas
From when I had a job. Offshore the Ivory Coast.
crashbumper
Gilbert, AZ
I don't have any pics of the shop, but I had some pics of the stuff we make.
Honda/Nissan/Toyota/Mitsubishi/Subaru
Up to and over 1,000hp, but usually the T6 Supra setups will make over 1,300hp.
Made of thick wall stainless and robotically TIG welded.
Uncle Buck
Kansas
I am a tower guy, do you people want to see some pictures of my looking down 300' to the ground below?
Adam
Lay it on em Adam, I doubt many other than you and me have seen many of those shots! (of course you shot yours, those I saw guys like you showed me! :lol_hitti)
tatra
pirate contest city
this is the size of engine we remove but we are not butchers or work as dangerously as these wild men..........that entire engine is being suspended by no more than a coupla dozen 5/8 bolts that have been subjected to enormous heat and cool cycles..........not to mention the exhaust manifold is only 1/16th plate...........also, takes less time to undo the blots with air tools tahn to burn them off...........effin butchers.........but gives you an idea of the size of engine in a unit.........
http://channel.nationalgeographic.com/series/break-it-down/3861/Photos#tab-Videos/06371_00
jsaw
Geneva, N.Y.
Our Fleet shop
caper
cape breton
Our Fleet shop
Have you got any closer pics of the engine crane setup for the Powerstrokes?I made one for the Ford dealer I worked at but would like to see how that one is done,especially where it attaches to the block.Looks interesting.:thumbup:
caper
cape breton
Here's a few from mine:
jsaw
Geneva, N.Y.
These are all I have at home, the lower brackets line up with bolt holes on the block. My partner built this one, but a heavier one is in the plans for the future.
The local Ford dealer has borrowed this one from us a couple of times.
Ray-CA
San Diego CA
Here are a couple of shots that were taken my last day at work...
Ray
Now Leaving , NJ
it was ramsey pontiac gmc in mahwah
closed up last year , but now owned by the same owners of paramus chevrolet - gene myers
that is the owner's 63 fi vette and it sits in his chrysler showroom now
caper
cape breton
why do you have to have that special setup
There's no room to hook up to a powerstroke in a van the way you would normally lift.There is just barely enough room for the oil pan to clear the crossmember and the valve covers to get by the firewall on the way out.Were talking about an inch of clearance,definitely not enough room to lift from the top so you have to lift from the front of the block.The problem lies in lifting it and keeping it level at the same time,hence the mechanism shown in the pics.
