snap on 936 series ratchet tooth count
stage20
pcola FL
these are somewhat older ratchets. im not up on all the snap on lingo.
does the 36 mean these are 30 tooth ratchets or are they higher count?
thanks
Fedwrench
Valley of the sun
Yes, crisp 36 tooth action that gets smoother and better with use :thumbup:
The 36 tooth series had a short run that got lost in the high tooth wars, which is kind of a shame because they were great ratchets. :beer:
Thax
Virginia
Like others have stated they are 36 tooth count and a pleasure to use. Snap on I believe no longer produces them , however J.H Williams USA made ratchets are a 936 ratchet in a slightly different body. Those are a great value for a great USA made ratchet.
Aqua-Andy
I have several (six in all I think) and have never really liked the action of the ratchet mechanism. I guess it always felt stiff and clunky with way to much back drag. Just today I figured what the hay, why not take one apart and see what's inside. I could not believe the length of the detent spring! No wonder it has so much back drag. So I cleaned all the parts and gave the spring a little trim (should have measured it) and put it back together. Took it apart and trimmed some more until I got a good feel. All I had on hand was some StaLube synthetic brake caliper grease so I lubed it up and gave it a try. It's like a new ratchet. I tried to make it skip or slip and it worked fine so I'm going to bring it to work tomorrow and put it through it's paces and see how it works.
gdocktor3
Connecticut
That's good to know. I'm so not a fan of my flf936 its in a drawer with my retired craftsman and SK ratchets. Now that you mention it I do remember the spring being really long when I rebuilt it. Maybe I'll snip a bit off and try her again.
Stevenn1
USA
Some examples-
F936: F=3/8" drive, 9=series (pear heads), 36=teeth
S872: S=1/2", 8=series (round heads), 72=teeth
T860: T=1/4", 8=series, 60=teeth
F80: F=3/8", standard length, 80=teeth
FL80: F=3/8", L=long, 80=teeth
FLL80: F=3/8", LL=long long (super long), 80=teeth
FLF80: F=3/8", L=long, F=flex, 80=teeth
*what I remember from the Snap-on rep*
shockwave
Marietta,ga
Yes they are 36 tooth I believe came out around the time of soft grips ratchets and the last of the USA stamps on the heads (a few early dual 80 had them) now always on handle
Wamsutta
Amarillo, Texas
Forget about what I said about the Sta-Lube grease. They changed the formulation. It's not the same stuff anymore. Use the official Superlube.
Aqua-Andy
I have been using my modified SO ratchet this week and I really like the ratchet action now. I will be doing this mod to all my 36 tooth SnapOn ratchets. For the life of me I can't understand why they made there ratchets so stiff. I agree the stiff spring would prevent the ratchet from slipping but there has to be a happy medium. What is the consensus on these ratchets Do people like them the way they come or am I just too picky?
Wamsutta
Amarillo, Texas
I'm assuming they made the spring stiff to account for wear between the pawl and the gear. I'm assuming the back drag gets less as the parts wear. I've never worn a 936 out, so I don't know what they feel like when they're well worn.
gdocktor3
Connecticut
Just estimate, how much do you think you cut off?
