Low voltage application only.Thanks for the replies. In the past, for this type of repair, I have always pushed the wires together end to end so they meshed and then twisted them for a stong mechanical connection. I then followed up with solder and heat shrink tubing, ...
Yes, factory connections are mechanical crimps because they are able to withstand the vibrations and flexing, in more conditions than soldered connections.Just saying there is a reason areospace repairs are done only with a mechanical crimp.
Avoid soldering
Avoid soldering
Avoid soldering
A properly executed crimps works very well, but so does a proper soldered splice. For example the NASA STD 8739.4 allows solder splicing via the lash splice technique. Solder splices are easier to execute and inspect. Mechanical crimps are better for a high vibe/flex situation but require specializes tooling and inspection including pull tests with samples etc.
On a connector, crimped terminals are preferred to solder cups since that is generally a high flex area.
To the OP: use the crimpers specified by the manufacturer.
The cause of the coolant traveling up the strands of the wire and into the ECM, was found to be improper machining of the coolant sensor brass end.GM had a problem years ago on temp sensors on cars having connections sealed so good that coolant would travel up the wires into the ECM and cause it to fail. They recommended cutting wire and soldering it back together to get the solder to seal the wire from coolant traveling up it. If you solder it make sure to strap it down so it doesn't move and vibrate loose.
+1
Not to mention, I doubt anyone at home has the specialized crimpers (which are calibrated) and MIL-grade connectors/splices. We have access to a LOT of them at work...
Were not NASA or building nuclear power-plants.... personally I've had luck with all three methods (crimp, solder and crimp/solder) for personal use. Just use a decent quality connector and crimper. Soldering takes a little more skill.
Avoid soldering
Is he working on a blower motor for a space shuttle? There's a reason that aerospace isn't SAE.
Different applications call for different solutions. .
Thanks for all the replys. I performed the repair with some uninsulated **** connectors, channellock 909's and some weatherproof heat shrink tubing. I was actually more interested in learning about the crimpers required for the connectors pictured in my first post. I assume that a quality crimper like this: https://www.waytekwire.com/item/569/MOBILE-CRIMP-TOOL-KIT/ along with the proper die would do the job?
-Brad
