Dryer plug / outlet to welder adapter.
Lacota
K.C. MO
I didn't say it was a good idea.
Useful on occasion.
Is it correct to say it will draw 27A maxed out.
This may prove interesting.
md21722
Mt Juliet, TN
Welders are generally rated as intermittent loads.
My Miller 211 comes with a 14 AWG cord on it and can draw 16.6A at 230V. I believe NEC will let me use a 30A breaker. What's the big deal? Just leave the 30A? breaker there.
Norcal
That dryer receptacle is not a grounding device, it's a dual voltage 120/240 volt receptacle, a leftover from the time when it was allowed to ground the frames of ranges & dryers to the neutral, but today it's only allowed in existing installations that being said, the OP's adapter is not code compliant but it "works".
laser3kw
northen IL
seriously- is your dryer in your garage?
I have an inverter tig that is rated the same way. I can plug it in a 120v outlet and run it at a reduced welding output or plug it into 230v (single phase) and run it at full output. I have a jumper plug that plugs into the welders standard 120v plug and then has a standard 3 prong 50amp NEMA 6-50 "welder" plug on it to plug into a standard NEMA 6-50-R receptacle.
L
Lacota
K.C. MO
I seen a mobile repair guy, have about 5 different adapters. Descent plasma would be another story.
taumac
Brooksville, Fl
Yes, it's also common in Fl to have W/D in garages.
OP. I've seen it done but I did it with a WH on a 50a circuit. I just put a outlet and plug on the feed to WH. I flip breaker off unplug the WH and plug in welder and flip breaker on. I worked in the rental I was in and owner didn't had a issue with it cause panel was full.
Zeke
Look at my sig line, 2nd one. I'd say about 50% of all single family dwellings in CA have the washer and dryer in the garage. Not every one of those has a 240v outlet though. Welders don't need anything but 2 wires to work on 240v but it's a good idea to have the neutral blade go to the ground of the welder.
What NorCal says is Bible. The neutral wires are never considered an equipment ground. But it will work using an 'adapter'. And the adapter stays with the welder.
A real welding dedicated 240v outlet will have 2 hots and a GROUND.
sberry
Brethren, Michigan
If this comes from a main service panel then while it's not code compliant it's wired correct. If it comes from a 4 wire fed sub then it isnt.
Git
S Cal
Reminds me of an 'adapter' I made when we were living at another house
I had a dedicated 30 amp circuit for my welder - but I also wanted to occasionally use a 240v 15 amp woodworking tool on the same circuit, an old Rockwell RC-33 Planer
over40pirate
This caught my eye, as I have the same planer.
Would using the 15 amp planer, be a problem, on a 30 amp circuit, if the planer had an elec. problem? Would it maybe melt wires in the planer, instead of tripping the breaker?
Big Daddy Chop Shop
Hope, Indiana
I grew up in a rental. Pops make an adapter and an extension cord for his Lincoln sparkbox, the garage only had 110. The dryer was in the basement of the house. When needed, he fed it thru the basement window and out to the garage. Not everyone has a "Garage-mahal", and believe me, my pops overdoes everything he does, but sometimes it is out of your control.
sberry
Brethren, Michigan
This depends but it is a violation to have a recept larger than the breaker its on in this kind of circuit. Did the planer come with a factory cord?
taumac
Brooksville, Fl
Explain this? So I have a 50a outlet, 50a wire running with a 40a breaker in a violation? Wouldn't it be just the opposite?
