realvc
My shop was built with 277 volt, 8 foot, T12 two lamp flouescent fixtures.
There are eighteen fixtures in this 30' x 60' building.
When I moved in I found a stack of these new in the box fixtures and have been replacing the ballast as needed from the stack.
Recently two of the fixtures would only light on one lamp and when I switch the lamps around it still will only burn on the one side so I've replaced the whole fixture using the new ones.
Two other fixtures will light on one lamp and after a time the other will come on.
The lights are wired up 240 volt and seem to work O.K.
I've been here almost 10 years and have gone through around 6 ballasts and 28 lamps plus replace the two complete fixtures.
I've priced new T8 fixtures and lamps would run around $1000.00
I'm trying to decide if I should just rock on with what I got or bite the buttlet and switch everything out to the T8's.
I had planned on doing this before I retired and now that I am retired the $1000.00 looks a whole lot larger than it did.
Thanks in advance for your help.
