Help with bubbles
8mpg
Hopefully you guys can help me out with some advice. I just laid down some Rustoleum Rock Solid Metallic yesterday. Im not thrilled with the outcome for a couple reasons: bubbles and coverage. The coverage is partially my fault as Rustoleum does not want you to grind/etch the concrete but use their wash. I had to grind due to the texture of my concrete being a broom finish. The bubbles was a complete surprise.
I have TONS of bubbles. After reading, I believe its due to outgassing, something I didnt expect. They were all air filled bubbles, no water. I ran over all of them with a roller once dry and they are all popped. I believe I have two options... double down after a light sand or get over it. Im thinking I might be able to sand down the rings left behind with a light sandpaper to remove the high spots, then apply another coat. Im assuming the 2nd coat wont outgas because it will be over the first coat that has sealed the concrete. Is this a good idea?
Pics of the bubbles/coverage:
Coverage...you can see the concrete in some areas...
8mpg
Would you put down a polyurea over it after a sand or do I need to get back down to concrete? Im thinking I should have gone with a polyurea to begin with. Im hoping that this could be used as a primer.
LegacyIndustrial
deerfield, IL
Yes you can sand the gloss off, wipe it down with denatured alcohol and go for it as long as it is epoxy.
Shea
California
Another cause of bubbles like that is from air entrapment from mixing. It's very important not to mix too fast or pump the paddle mixer up and down. Doing this can create air bubbles that get rolled onto the floor.
8mpg
thanks for the advice...definitely something I wasnt thinking about.
Theo911
doesn't backrolling over the product pop the bubbles created while mixing?
