It's cool, but what is it called?
thegroundpounder99
Balm Fl
When you twist the handle, only the 1/4 drive moves. Anybody seen or know what it would be called?
Sent from my LG-H634 using Tapatalk
gorilla
Look's like it might be a tool for adjusting idle air screws on carburetors.
Roju1985
I've seen them used to adjust carburetors, not sure of the name though.
fatfillup
Finksburg, Md
Definitely a carb tool and also gm distributor tool. Likely came with a screwdriver socket or 2, allen socket and a few others
JRC3
Southwestern OH
That's a thingamabob. Some might confuse it with a thingamajig, but it is in fact a thingamabob. Hope this helps.
lugnut71
Wyoming
snap on sells another version that is flexible, its awesome!! put sockets on it and run something out once broken loose, or use it to start a fastener that you cant get your hands on. Well worth the 25 bucks.
gonmad54
Temecula, CA
It's for adjusting carbs. I have a kit that I bought off the SO truck probably 8 years ago. I'll add a picture when I get home.
3 Gun Shooter
You use it for adjusting carburetors and GM points, kit should include 3 different flat screw driver type sockets and a ball end allan wrench socket. I also bought a double D socket for later Quadrajets.
It's a Snap On/Blue Point tool, Snap On also made one with a flew where the bend is.
bonneyman
Desert SW
I made one not too long ago, as my 80's truck has a carb, and so few shops will actually work on carbed vehicles.
wasfuzz
Mn
Is it right handed or left handed ? Makes a difference on which Carb you use it on!
^ this. some were made with a short section of flexible shaft at the drive end - we sold them in Indestro - full kit was a #2820 - attachments were available separately.
mostly for GM Quadrajets and 1957-1974 GM V8 distributors, as I recall.
T
thegroundpounder99
Balm Fl
I knew you guys would know. I had a exciter wire on a starter just being a PITA and guy had this worked awesome. He didn't know what it was either but I bought it at the price he paid at yard sale couple weeks ago lol.
egnorant
East Texas
Looks like just the thing for reaching those dashboard screws that are at the base of the windshield1
Bruce
