Pictures of the Shop!
Side Porch... still need to finish the wainscoating this weekend and start on the porch ceiling now that the electric is done for that portion. I redid the corners for stone as the contractor had things screwed up. The porch posts will get a PVC wrap with caps on top and bottom. You can see a sample of it on the first post. The door straight back goes into the 1/2 bath. More on that later...
Now for some interior shots after concrete. Floor has been done with a cure and seal product during installation to keep the concrete from drying too fast. Everything was saw cut after installation. The floor turned out really nice.
You can see the service in this first picture and the spares that run over to the house.
Water Hydrant between the doors, its fed with 3/4" poly. I'll mount a hose reel on the wall behind it once metal is up.
The mower/atv door on the side. Its 8'x8'. Im using high lift track and a liftmaster 8500 opener. You can see the floor drain thats still covered right now.
Door on the right goes into the 8'x10' 1/2 bath. The door on the left goes in the the 32'x10' dirty room thats enclosed under the lean to. Wall hasn't been built yet that will seperate the two rooms. You can see the vent/rough in for the full bath that will come later on the second floor.
Standing in the bath looking into the dirty room
Looking back the opposite direction
Closer look at the 1/2 bath... closest pipe in the floor is the toilet drain, then the vent on the wall/sink drain. There will be a mop sink that sits into a cabinet/counter top. The plumbing on the wall next to the door is the 3/4" poly that runs to the water hydrant. There is also a 3" pvc pipe in the floor that you can't see that is stubbed to the outside that I will run the water line from the house up into and tie the two together.
4 post lift will set here. Cabinets and work area on the back wall. You can see one of the 1.25" spare conduits that is ran outside for future use if needed. I put one on each of the 4 corners and then ran it up above the carriers and strapped to the truss using 1 hole straps.
2 post lift will set here. There will also be a staircase in the back corner that runs upstairs. Ill sit my compressor in the room under that staircase.
Any questions, feel free to ask!
