More drama with this never ending project!
I took John's advice and used the rod ends in the setup:
That worked out pretty well (thanks!) and now the track is secured, no chance of bending the angle bracket and can pivot so no track spreading. Good.
That took a while but I finished today. To be sure I got the track level and didn't tighten the brackets too much I put the trolley in (not connected to the hoist) and everything was smooth.
I then bolted the trolley to the hoist and got it up the ladder and put it in (not fun on the top of my a-frame). Here's where the trouble starts. I got the first trolley in the track and got stuck on the track bracket where the hoist bracket is. It didn't occur to me to try the trolley with the hoist attached. Grrr.
I wasn't sure where I went wrong until I checked Rockcam's setup:
It turns out the extra height of the narrow unistrut I used for the trolley-hoist mount is too tall and makes the hoist bracket too high (which I think is part of the issue). More important, the bolts are in the middle rather than towards the top. Rockcam's setup does not take up the entire space under the hoist brackets and the bolts are towards the top end so the hoist brackets will sit lower in comparison and clear the track brackets.
So now I have to find another method of attaching the trolleys to the hoist. I would have gone with Rockcam's method (iron rectangles) but I was unable to find them locally. All the box stores had was angle iron which would not work.
Can anyone tell me where I might be able to find the rectangle iron? Or any other ideas?
I could grind the unistrut slots so the bolts can sit higher but I fear that will weaken it.
Thanks!
