Qualitytools
Very nice Superautobacs, really enjoy the vids
Thanks!
Those look like a slip joint version of the PZ-58 Engineer pliers, yes?Are you talking about one of these patented pliers?
Thanks for sharing the videos of tools that I haven't seen before but, now want to spend snap on money or more to get
That Nepros 1/4 drive flex head ratchet with the pressure pad to prevent head flop and the hollowed out handle is an over engineered badass ratchet![]()
YES thats the lobster i was talking about!
I have the engineer slip joint but i am dis-satisfied with it.
It probably happened while removing some pesky harness holding clips inside a car door.The Engineer's are considerably shorter which equates to less leverage. It cannot grab on to really hard screws that good. The grip is about 2.5mm (.100") slimmer than a Snap-on at 14.5mm (.570") versus 17mm (.670") width.
I struggle to use all my force to grip, maybe im the wimp?
It didn't take long before the shrink wrap on the stubby ANEX trim clip removers were damaged.It probably happened while removing some pesky harness holding clips inside a car door.
And photo comparison with a more conventional size:
I think so too. Thankfully I don't have crazy OCD wanting to replace it with a ANEX original (yes, they sell replacements).
For sparkplug removal....
Using my go-to locking extension with free-spinning sleeve (Wera), FPC locking universal, and Ko-ken sparkplug socket.
9 out of 10 pimps choose Flash Tools...
From part of FPC's catching/locking series is these dual-purpose "catching sockets":
Shallow and deep in the common sizes used in Japan
There's some obvious differences from Ko-ken's nut-catchers. Ko-ken uses two balls; FPC uses one.
What's unique about these is the dual-purpose function. You can choose to use it like a standard socket (with or without retention) by rotating the band:
One of their interesting product line from FPC has been their locking and retension accessories.
I MUST have this!
Trying to picture a scenario where this locking universal would come in handy. I cannot find a scenario so my wallet is not hurting.
Some very nice quality tools btw!
superautobacs. Right on cue!
I was just on the lookout for some locking extensions.
Do you find the hex on the driven end any good for fast hand spinning?
The first thing that springs to mind is spark plugs that are hard to reach, but mostly every once in a while I see something that I just have an irrational desire to own. A Proto J4752FBL is on that list. The last thing I need is another standard-length non-flex 1/4" ratchet...
If you're concerned about leverage/length, of all the brands that I know of, I think it comes down to these three brands (Lobster, Engineer, and 3-Peaks):
Lengths:
Engineer PZ59 = 200mm
3-Peaks DS-215TZ = 215mm
3-Peaks DS-200 = 210mm (this is a locking plier type (first picture below is the shorter DS-130))
Lobster TG200NA = 200mm
Grip width:
Engineer XP = 15mm
Engineer PZ59 = 19mm
others unknown....I can tell you that the grip width on the Lobster is pretty standard.
Hardness:
Engineer PZ59 = 60 +/-2 HRC
3-Peaks DS-215TZ = 50-58 HRC
3-Peaks DS-200 = 42-48 HRC
Lobster not known
Don't forget the Merry pliers ZA 185
Hardness around 25 HRC...
http://www.garagejournal.com/forum/showpost.php?p=3764043&postcount=679
http://www.garagejournal.com/forum/showpost.php?p=3813767&postcount=693
Looks cool, but I can't help but think that thing would be slippery as heck with oily/greasy hands...
