Garage/Cabin
horhey
MN
Actually started this project last year but thought I would throw it out here. Purchased a lake lot in MN and decided to build a garage with a loft so we could use it as a cabin until we want to move to the lake permanently.
H
horhey
MN
More progress....
LXCam
Very nice. Where's it at, the area looks like a great place.
H
horhey
MN
Thanks. It's located in central Minnesota.
H
horhey
MN
Thanks. We are going to use it as a sleeping area for now. The siding on the outside is box steel but the interior I used what is called Barnwood siding at Lowes. It comes in 4x8 sheets that we just stapled up.
H
horhey
MN
Here are some progress pics of the inside and one with the siding finished.
H
horhey
MN
We decided to do steel on the ceiling and on the bottom 3 feet. The top portion I used 1/2" 4x8 siding from Lowes that looks like barn wood.
I have sheet rock in garage at home and don't care for it. I ended up scarring and denting it as I am not careful enough. This should stand up much better.
H
horhey
MN
Indoor progress. I still have some screwing to do on the ceiling.
H
horhey
MN
Last set of pictures. Once we build our house on the property (hopefully in 3 to 4 years) this will become more of a garage/man cave.
I still have work to do on the work bench area. I put up some pegboard and will be building some storage above it.
Still debating on what to do with the floor. I really like the look of a clear coat but a little worried about it being slippery and standing up to a snowmobile driving across it. We like to ice fish and ride snowmobile and will be parking the in the garage so there will be plenty of snow tracked in to make it slippery.
grissom
Brown Engineered Untreated Wood Siding Panel (Common: 0.437-in x 48-in x 96-in; Actual: 0.406-in x 48.563-in x 95.875-in)
Item #: 15601 | Model #: 27905
http://www.lowes.com/pd_15601-132-27905_1z11pro__
Hope this works
Thanks, the link worked however the closest Lowes that has it in stock is 2 hrs away. No wonder I have never seen it before
Did you put some sort of finish on it?
H
horhey
MN
I noticed they only stock it at certain stores.
Since we are using it on our interior we are not putting any kind of finish on it. I think it will hold up pretty good based on the reviews. I sure hope so anyway since I did the entire place in it! It seems good so far and I did the bathroom and the attic last summer.
burleyfarm
Northern Michigan
Horhey
I have an epoxy floor in my garage and store snowmobiles in it in the winter. Love the epoxy but it can be very slippery when wet. We used non-slip in the clear coat, extra in the walk ways and in front of doors.
I bought an "Eazymove" dollie to move the machines on and out. Otherwise your carbides and studs will scratch the epoxy. My friends use the same dollie in their garage with an unfinished concrete floor and like it. It is very easy to use. I'm only 5'6", 145# and can move machines around very easily. Www.eazymovecarts.com
Hope this helps you out.
Sent from my tractor seat.
rlwhitetr3b
East Central Illinois
I just noticed that the siding is listed as being for not residential use only. What is that all about?
I misquoted the Lowes site. It should have been "For non-residential use only". I think that would mean that it should not be used for residential applications. The manufacture's representative in the comments section on the Lowes site says otherwise.
H
horhey
MN
burelyfarm, Thanks for the feedback. That is exactly what I wanted to hear. Experience from people that have already been there and done that.
Grizzly Guy, Thanks. We love spending time there now and it will be used heavily when we start building. Right now I only have "some" of the necessity type tools there as I don't want to buy 2 of everything or should I say can't afford to buy 2 of everything.
tlwhiter4b, To be honest I didn't even see that part of it and thanks for the feedback.
AZpilot
Mesa, AZ
Is a lake lot in Minnesota like a desert lot in Arizona? They are everywhere?
AZpilot
Mesa, AZ
Very nice weekend getaway. The living area will make a nice wood shop once the house is built.
H
horhey
MN
AZpilot, There are 10,000 lakes so there a few of them out there. I am looking forward to using it as a garage/man cave as I do small projects in it now but am limited by space and creating too much dust according to my wife.
bww_mnm
Chicago area
License plate of mn "land of 10,000 lakes". I believe there are closer to 14,000 though.
bww_mnm
Chicago area
Wikipedia: list of lakes in Minnesota. Although promoted as the "Land of 10,000 Lakes," Minnesota actually has 15,291 lakes of 10 acres or more, but only 11,842 of those lakes are "officially" counted by the Minnesota Department of Natural Resources.[1] If all basins over 2.5 acres were counted, Minnesota would have 21,871 lakes
H
horhey
MN
bww_mnm, I stand corrected although some of the lakes they have listed as a lake are basically a swamp or slough.
