Hey all, I'm getting ready to attempt my first re-motor project and thought it would be smart to get a little expert advice before I start. I'll say up front that I'm no electrician, but I'm familiar enough with Ohm's law to keep from hurting myself
I bought a clean Wells horizontal bandsaw that was set up for 3-phase power. I have the correct single-phase replacement motor ready to install, and it currently has the leads set for 240V service. The motor shows a max of 4.4A current draw at 240V.
Since the saw was three-phase it has a magnetic starter switch, which shouldn't be necessary for single-phase, correct? The saw also has an automatic shutoff switch wired to the start/stop control box.
What I was thinking of doing was essentially bypassing the current wiring setup, adding a service disconnect with midget 5amp fuses, and then running a simple heavy duty on/off switch....essentially leave all the old stuff in place other than the wires to the motor and the automatic shutoff relay (guessing it's a relay, but I haven't taken it apart to look).
Am I missing anything obvious, or is this a dumb plan?
I've heard/read that some folks have retained the original wiring and used it to power the replacement single-phase motor, but that seems overly complicated for no reason (unless I'm missing something). This page covers a magnetic starter to a single-phase motor:
http://wiki.vintagemachinery.org/motor starter wiring diagrams.ashx
I'll post a couple of pictures of the current setup for reference.
