MG David
Thomas, thanks for all the detailed shots. It is a lesson in the value of good planning.
Hi there KST1 and thanks for that information. Do you happen to know if residential homes are being built utilizing plaster? Plaster repairs to existing homes with plaster I understand, but new construction?
Thomas
Well Thomas and Chris, after 5 months or so I have made it to the real-time end of the vortex!
There is such a great mix of history, restoration, repair, construction, recycling, conservation and education in this thread across several fields it's easy to see why it's enjoyed by so many.
I can't add any more sentiment to what others have already said, other than to say thanks for sharing what and as much as you have.
Cheers Grumblebum.![]()
Maybe he'll see here we're trying to reach him. In my part of the world plaster is still quite much in use. Makes a solid surface, without the joints between drywall sheets, with their possible cracks.
I'm curious magnusk if wood lath boards are still being used under the plaster around you? Also, is horse hair being used as a binder in the plaster mix. The plaster in our old family home had both. Plaster certainly muted sound transmission between rooms.
Thomas
Since you're so close to Lyndon in Sydney, next time you see him tell him I'm still trying to get an update on Beltsville Shell. The gentleman who has it presently is incommunicado.Maybe he'll see here we're trying to reach him.
Thomas
Monticello is a great little town, one of my favorites. I did my student teaching at the high school there many, many, many years ago. You can still get real gas there at the FS station with no ethanol.![]()
Thomas
Thomas, I really enjoy reading your thread – especially now that you’re building your house. I find this most interesting. I wait up nights to be the first to read your post for the day. I don’t know how many folks realize all the work that goes into building a house but you are also documenting every step and reporting on how it’s done. That alone is a timely job.
There are so many different ways to achieve the same results but I never know which is better, that’s why I have so many questions. When we built my shop and garage the inspector requested a 4 inch high concrete curb between the garage and the shop because he said a cars gas tank could leak and flow under the wall into the shop where we had the furnace and water heater. In your case the gas could leak down the basement walls. Has this been inspected yet?
I noticed the supporting basement walls – one wall has 3 - 2x6 top plates and no 2x12’s headers over the door. The stair well walls have 2x12 headers but only one top plate. Reason?
The hanging floor truss system is really nice. It allows no steps from the garage to the living space (great for us older people). But it has also lead to some minor design problems – the removal of the last course of blocks on the chimney. I also noticed that some of the beam pockets may have been installed too high. It looks like some of the beams had to be notched and an angle attached to the wall in order to lower the beam. Or was it designed that way? One last question – Why weren’t all the beans installed at the same level and all the trusses made to hang on the beams. That would have given you a flat level ceiling with no obstructions below.
You’re going to love those open trusses with it comes time for plumbing, electrical, and ductwork.
I really want to thank you for all the work you put into this and sharing it with us.
Bob
Also I just noticed some of the beams have a 2X on top (between beam and truss) and some don’t. How is the truss attached to the beam without the 2X ?
Interior walls all still plastered here using gypsum based plaster usually on top of insulated platerboard slabs, just doing the joints is only done on very low cost construction
Hey All, I wonder what the Vegas odds are on the basement steel beams being powder coated or not ????---- Headed to The Center of The Universe, watch out.----Lou----
Thomas
Here's a video that makes you feel like a master of plaster and the Swedish Chef in The Muppet show in the same time:
That's already been done by another GJ memberWhat you need is an underground tunnel to the garage.
That's already been done by another GJ member![]()
Thomas
I was wondering about that, but didn't want to interrupt - you seem to be unbelievably busy at present.
Keep up the great work.![]()
Lyndon
Sitting quietly in the corner.![]()
I'm happy to report Beltsville Shell should be in the mail to Maryland this week. David finally got hold of me and told me he'll be sending it out shortly. Dennis, the new recipient, has been alerted and told me he's on the lookout for it and he'll get cracking on it since the Australian contingent is chaffing at the bit to receive it. Good news all around.
Once Dennis is done with it he'll mail it back to me. I'll then prepare it for the long trip down under. You're 1 reader away from it finally coming your way Lyndon.
Meantime would all you fine fellows in Australia make sure everyone there knows the current list order and mailing address of each other that it will be sent to. The Australian list got changed around with a little bumping into line and I'm not quite sure how it all turned out. Lyndon, would you post what you believe to be the final list. Then if there any additions or subtractions we can have that all finalized before I send it to you.
Thanks for all your patience. I'm confident it'll be worth the wait.
Thomas
) so it will be hard to find. Just pop over to my smaller thread and post up the interest there.
Post #9230 (pg 462) has the all-important list:
- Lyndon - Sydney, Australia
- VMX42 - Sydney, Australia
- 1/2 Cup - Shepparton. Victoria. Australia
- Nursepeter1973 - Western Australia
- BBChevro - Brisbane, Qld., Australia
- Gatsby - Canberra, Australia
Chris
I don't know. I've been to Brisbane, and once things go there, they don't come out the same. I know I didn't.![]()
Thomas/Chris
I think we are nearing a list down here:
- Panthersteve - Brisbane, Qld
- Gatsby - Canberra, ACT
- Grumblebum - Wollongong, NSW
And Rod will bring it back up to me.
If he's interested we might slot Hotfr8 in after 1/2 Cup. I'm waiting to hear.
And at this point I think (?) we have it nailed.![]()
I will then be responsible for packaging it and ensuring it makes it's way stateside correctly and safely.
Lyndon
Shheeeesh!!!![]()
Something we need to be aware of is our super s...l...o...w... mail system here now. I was made aware of a mail delivery that took 14 days when it should have been overnight delivery. I have also experienced mail from Castlemaine to Melbourne posted Thursday arriving on Wednesday the next week and usually that should be over night or 3 days at the most.
I am sure it will get to NZ faster than it will between readers here.
Yes something posted overseas can be delivered here now faster than internal mail deliveries and our mail cost went up as well. Adding to that our Express Post is no longer guaranteed.![]()
Simon
I'm not experiencing any of that..... I had a parcel posted in Melbourne on Monday, and we got it Wednesday (thankfully - it was my daughters birthday present that I got on Flea Bay for her).![]()
There is now a fast and slow postage for letters, for which you pay extra if you want the fast option.![]()
And - do you want to be on the Aussie distribution run?
Sorry Thomas for discussing this here. It is on my thread too....![]()
Lyndon
Wasting time on a Friday arvo![]()
Oh well, I best waste some more time and see what every one is up to.What is that! Time on the GJ is wastedOh well, I best waste some more time and see what every one is up to.
