How do you torque a nut to 350 ft.lbs?
larry_g
oregon
One option is to use a torque multiplier. Another way is to divide the 350 by your weight and that will give you the lever length of the handle needed on the bar that you stand on. Example, you weigh 100 lbs, 350/100= 3.5. The handle length would be 3.5 FEET long.
lg
no neat sig line
Strouty
Southern Maine
My 3/4" torque wrench goes to 500 or more foot pounds, it is an older proto, should not be that hard to find one like it.
I only paid $50 for mine and it was tested on the Snap On truck for accuracy, it read 10 pounds high at 250 ft pounds, but when you get into the 500 ft pound range, what is a couple of percent between friends.
Mr. T
Central PA
lg
no neat sig line
I'd use this method if it means buying a $500 torque wrench and socket will be avoided for a one time use. Just remember to hold on to something when you're standing there.
But if it's a critical fastener that could lead to catastrophic damage to persons or equipment if done improperly it might be best to spend the money or farm this one out.
Mr. T
Central PA
One ft. lbs. at a time.....
Seriously, it may take a torque multiplier like this:
http://www.northerntool.com/shop/tools/product_200623947_200623947
It takes a really high torque value and some specialized stuff to get make a torque multiplier worth the investment.
Because they use planetary gearing there is a loss in the force through the transmission. Because of this you need to measure the output torque of the multiplier to have any confidence that it is correct. Very spendy if you go that route.
joe_padavano
Northern VA
I see 3/4" torque wrenches only seem to go to 300 lbs.
Funny, I've just had to do this today for the pinion nut on my truck's 14 bolt axle. I also have a 600 ft-lb, 3/4 drive torque wrench. I think I paid $65 for mine at a swap meet.
Yeah, it's about this long...
royesses
I had a Snap-on 600 ft/lb split beam torque wrench for CAT cylinder head bolts at 330 ft/lb.
Wes J
Peoria, IL
My KD torque wrench goes to 600 ft-lbs.
Proto, Wright, and others make 1" drive torque wrenches up to 1,200 ft-lbs.
WhiffySpark
If you're talking about an axle nut I use a 2235 and a finger. If youre talking about head bolts. Yeah there's no cheap way
J
Jacobson
Cool idea about standing on the bar. I guess you just hope the bar is sort of close to level when it reaches fully torqued. For a 1 time use, this is what I'll try first.
toplessHO
central florida
175# person 2 ft bar
pretty simple
you can use a longer bar but torque is calculated from middle of point of contact
this means if your using body weight and both hands are on the bar,feet off the ground,
the calculated length should be middle between both hands
and do not bounce
foghorn1966
N. Alberta
Rent a 3/4" torque wrench. Any good rental place should be able to help you if the fastener you are working on needs to be torqued.
larry_g
oregon
If you are not at 90* the your error will be the cosine of the angle your at.
it's perty simple math.
lg
no neat sig line
