Worst tool description ever.
Bustedwheel
Really? I never have, but still, I doubt they use this to assemble rolexes
Mike83
Wisconsin
Its a bad description because inch-pounds is not a measure of force, but torque. Inch-pounds are used to inflate the rating of the tool I think. 1044 sounds like a lot more than 87, despite the fact that 87 ft-lbs is more conceivable/practical in most of our minds.
GearBeer
Inch pounds are pretty common in the automotive world when it is important that a small bolt is torqued accurately (i.e. a sensor retaining bolt).
tdkkart
Eastern Iowa
Exactly my thoughts.......
I use my inch/lb torque wrench far more than I use my ft/lb one. Of course most of what I work on is go-kart motors and my Harley.
Anything under 5/16 or 3/8 is better torqued in inch/lbs, ft/lb torque wrenches aren't super accurate in the lower ranges.
krooser
Waupaca, Wisconsin
Inch pounds ratings are very common... what I hate is the guy who decided to change "ft/Lbs" to "pounds feet of torque"...
MotoDave
Ventura, CA
Technically it should be 'foot-pounds' or 'inch-ounches', as torque is a force multiplied by a distance.
ft/lbs implies 'feet per pound'.
If you really want to get technical all the forces should be pound-force, so as not to get confused with pound-mass.
PistolWhip
People's Republic of New Jersey
Inch Pounds are used for 3/8" and 1/4" torque wrenches all the time. I have quite a few and use them all the time for things like intakes, throttle bodies, plenums, timing covers, etc... Anything that requires a torque that's less than 75 Ft/Lbs, I step down to my In/Lbs torque wrenches. They're usually more precise for smaller torque levels than a large, cumbersome 1/2" Ft/Lbs wrench. It's not something that's new, its just a smaller scale of measurement.
stimpee
Gallatin TN
You actually contradicted yourself in this post.
force * distance = torque
lb (or lbf) * feet = lb-ft (hyphenated for convenience)
lb * inch = lb-inch
ounce * inch = ounce-inch
Hence the use of "pound-feet" instead of "foot pounds". Pound feet is technically the "more correct" term, if there is such a thing.
lb/ft is entirely incorrect as it has been pointed out, since it implies division.
Fun stuff huh?
MotoDave
Ventura, CA
I maintain the result of force * distance or distance * force is the same, therefore it doesn't matter in which order you say it :)
I was just pointing out that ft/lbs isn't correct, though the intent is widely understood.
Kewl Bus
NE GA
1 ft/lbf = 12In/lbf
1in/lbf = 0.083333333 ft/lbf
For those of you that want to do the math
e-tek
Saskatoon, SK
When any of you are using inch-pounds, do you convert from the ft/lb reference, or what? I've never seen any references listing any torque requirements in inch-pounds.
That being said, thanks for the conversion table - I think I'll convert for some of the smaller fasteners on the 240Z I'm doing.
airbassador
Change the rear pinion seal on a later F250 Powerstroke Ford. That requires an inch-lb measurement, and you don't want to get it any tighter than recommended.
I bet you're feeling pretty silly now for starting this thread aren't you. :)
This will help:
http://lmgtfy.com/?q=inch+lbs
Moose-LandTran
The Brink of Insanity (England)
Over here (England) we say "pound per foot" if you said "foot-pounds" you'd get some funny looks.
MotoDave
Ventura, CA
'per' implies you're dividing one unit by another, and is not correct in this case.
psi = pounds/in² = pounds per square inch
JCQuick
Apopka Fla.
I have a friend that works on turbos for some nice race cars they require inch lb torque wrenches. you do not want to twist some of those exotic shafts
Hodge
In the bicycle industry, 99.9% of stuff is in inch Lbs....
Cheers and beers
Hodge
