gathanas1970
TL-13-A
US Army Signal Corps, lineman's pliers
+1I like Völkel:
http://www.voelkel.com/en/produkte-en/gewindewerkzeuge-en/handgewindebohrer-en.html
All my rethreading kits are V-Coil, by them. They're very good.
Todays makers could take a QC lesson from the old plier makers.
I *think* the Drehmax is made by Witte.
I don't know the vintage of your Knipex, but I'm curious about the one on the far right. Is there a part # on the handle?
IMG_20160604_101608 by Hel Fel, on Flickr
IMG_20160604_101513 by Hel Fel, on Flickr
IMG_20160602_130927 by Hel Fel, on Flickr
IMG_20160602_130933 by Hel Fel, on Flickr
IMG_20160602_131058 by Hel Fel, on Flickr
IMG_20160602_131103 by Hel Fel, on FlickrHey Hautpot are you back?I am certain that Knipex Cable shear is 95 11 165A (the "a" is very important)
What is the A in knipex above stands for?
Hey, guys... here is part #2 of the Hazet factory tour:
JP Performance - Zu Besuch bei HAZET | Teil 2: or "
JP Performance - Visiting HAZET | Part 2"
If anyone knows German; if you could give us a basic idea, of what is said in the video (for us english speakers), it would be appreciated! Thanks!![]()
FWIW, I'm accustomed an initial item release being given a purely numerical P/N. And a letter that follows, signifying a revision; whether it be an improvement and/or cost cutting measure as a general rule.The extra letter is unknown nomenclature for me, but I noticed that extra letter differentiate the two pliers.
! These are vintage Wittes
!!!! I had no intentions of buying them (because I like bits), but I couldn't take pictures so I decided to buy themWhere can i get one of those?
Nice find. Barely look like they've even been touched, let alone used.Now the whole point of this post; showing off my (secondhand) pair of course
The built-in wire stripper is a bit fiddly, but works in a pinch.
I had posted this previously in the "Tools from Japan" thread, but since we're talking about Japanese knives, here is my collection:
From the left;
Shun Kramer damascus parer
Shiki damascus 120mm petty
Carter 165mm wabocho
Hattori 270mm sujihiki
Kumagoro Hammer Finish 165mm nakiri
Nenohi Nenox G-Type 240mm gyutou
Misono Swedish carbon steel 210mm gyutou
The Carter is, actually, a ringer - it was made in Oregon. Murray Carter, however, spent 15 years blade smithing in Japan and was awarded the title of a 17th generation Yoshimoto bladesmith. The Carter and the Misono are probably my favorite knives.
What brand are the boots?
*snip*
In the case of the Knipex cutter images you posted, I notice the top version doesn't indicate a COO, while the bottom image does. So there may be a bit more than just a change in the jaw profile/shape to result in adding a letter to the end of a numerical P/N.
Hope this helps.![]()
Yeah, Knipex uses letters after the product number to distinguish between different variations of a certain type of pliers. I first saw this when I was looking up some info on the 97 00 215 A crimping pliers:
Rennsteig Pin Punch Set, Engineer Neji Saurus RX, York Sanding Sticks, Wera TX20 for Spax T Star
