atikovi
Trying to remove this I assume original sensor on 180,000 mile car. Been alternating use of Areo Kroil and Mini Ductor until red hot and letting it cool, then using two types of sensor sockets, ratchet and cheater bar with no luck. Can sense the socket going to round off sensor if I try harder. Plan B was to use a deep 6 point socket but the sensor body is too thick to get it down to the hex part. So I need to cut it in half. No room for a reciprocating saw because of that shield. Looks like this Aircat 6275-A would work: http://aircat.com/products/die-grinders-cut-off-tools/4-composite-inside-cut-off-tool/ I can get for $173 or this Dynabride 18075: http://www.toolschest.com/mdco6741.html for $195. Thoughts? Want to avoid dropping the exhaust as much as possible.
