Making a refrigerant recovery tank
killahog
Morrow County Ohio
I picked up a manifold gauge set and a vacume pump at an auction today and was explaining to a friend that I needed to find a recovery tank. He told me where he works they routinely made them out of empty R134 tanks all I would need is a valve. Has anyone on here done this? from what I read there is a check valve in the newer tanks how can these be modified ?.
walrus
Maine
I don't believe it's legal to use old refrigerant tanks. Plus they aren't safe to use in that fashion.
LS6 Tommy
Northern NJ
It's not legal, not easy and definitely unsafe. The same thing goes for turning them into portable compressed air tanks. All disposable refrigerant cylinders have a check valve. They can't be refilled. Besides, how were you planning to recover the refrigerant?
Tomm
K
killahog
Morrow County Ohio
Tomm
I was planning on recovering the refrigerant with a vacuum pump, after doing some reading it didn't take long to understand why using one of those is not a good idea. However I can see several reasons why a mechanic would do so possibly to recover some refrigerant from a vehicle that was going to be scrapped and then take that tank home.
Dagny
Northern Wi.
134a is too cheap to justify it . I have silver soldered 1/4 inch fitting on these tanks for a variety of reasons over the years.
2mJps
north central Mo
I would like to do the same thing. Why couldnt you use a propane tank. What stops me from reuseing 134a is i would like to filter it some way. Maybe some kind of filter could be built? Some one is doing what we want to do we just need to find them. I dont do much ac work or i would be trying some thing.
mikebaker1129
Huffman,TX
Yes it can be done,but it is against DOT regulations to transport a refilled throw away cylinder.
Propane tanks are very similar to the recovery tanks sold,but you would need to purchase a recovery tank valve to install into your tank and the valve cost almost the price of a new tank. Last new tank I purchased new was about $70 for a 50lb tank.
Pull a vaccum on the tank,put it in the freezer over night and then connect it to your car that you want to recover from. Liquid is more dense so I normally get as much liquid as I can first.
I have done this when recovering on a hot roof in Houston even with a machine,using a ice bath on the cylinder to keep it cool.
You can only refill 80% so that means 40 lbs in a 50,24 in a 30lb cylinder.
You can install a filter drier inline to filter out contaminants. We do this to protect our machines from debris.we can pick up used tanks here for around $20 on Craigslist.
Good luck.
zmaxmotorsports
South of omaha
A vacuam pump is not made to be pressurized,I tried a stupid experiment 20 some years ago.
It was an expensive experiment!:shocking::lol:
