My industrial style coffee table
L84ARACE
I pulled this out of a barn and made a coffee table out of it.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Added some old reclaimed lumber & 4x4's for the base....
[/URL][/IMG]
59'trump
Sounds good, but I can't view the photos
whateg01
doo dah, kansas, usa
I really like that. I've been looking at "industrial"-themed furniture and so much of it is built around pipe and pipe fittings. That's not the look I'm after. I could go for your table, though!
Dave
tarbellb
Oregon
Well done! That came out great, was worried it was only going to be 6" high till the last photo.
PFSard
Mesa, AZ
Great job. I would never have envisioned the end result given what you started with.
L
L84ARACE
Wow. That's really nice! What did you use to keep the cuts in the sheet so straight?
They are not perfect but the piece is rough enough that you don't notice unless you look very closely. I drew it out on acad first to get the measurements and rivet spacing.
[/URL][/IMG]
L
L84ARACE
Pretty cool! After drawing it out how did you make the cuts?
The brooder unbolted into 4 wedge shaped sections. I laid it out to see how large I could make it, and cut the pieces down with a metal shear. The center piece was a rectangle cut from another piece of metal. The pieces overlap each other, so I didn't have to 'gap it' perfectly which made it much easier to fit together. It is mounted to 3/4" plywood underneath which is sitting on 2X4's on end. Then I just pre-drilled the holes and pounded in the rivets.
Edit: I found a photo of the process.
[/URL][/IMG]
L
L84ARACE
Thanks for the kind words everyone. I messed around with this off and on all winter, really struggled at times, and almost through in the towel.
